Question about Oki Electric Industry MC860 Mfp 3 Tray 120V (efps) (62431405)
When scanning to email on the MC860 3 tray, we get a thin black line on the right hand side of the page. Shows up in the email and when printing the email. Happens with flatbed and with the adf.
  • 905 Answers
Normally, this occurs on the document feeder since the pages pass by a relatively small area of glass. They can leave behind debris which is visible to the scan head. This doesn't often happen on the flatbed part, since opening and closing the lid tends to blow off the debris that has accumulated.
Since the line occurs on both the ADF and the flatbed, there is debris on the scan head itself (the part that moves back and forth). If you are able to access the head, then you can blow it off with canned air. Otherwise, a technician will need to come and disassemble far enough to blow the head off.
Posted on Aug 19, 2010
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Black solid line on the right hand of page when
Hi, remove the black drum and clean the corona wites and drum GENTLY with a LINT FREE CLOTH. If there uis no change in the print quality you may need to replace the black drum. Hope this helps
Feb 18, 2010 | Epson Aculaser C1100 Printer
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Thin black line 1.5 in from the right side of the paper going down the whole page
If it doesnt have a line on it when you scan it and open up the document then it's not going to be a scanner issue, more then likely, it's going to be an issue with the toner of the printer you are using to print with. Check the drum on the toner and you'll probably see the line in question on the drum itself. You'll just have to push back the flap that covers the drum on the toner if this is a laser printer... hope this help's if it does, please mark as a FIXYA!!
Oct 06, 2008 | Canon DR-9080C Path-Through Scanner
Thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Feb 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Oki Electric Industry MC860 Mfp 3 Tray 120V (efps) (62431405) Logo
140 people viewed this question
Top Oki Electric Industry Computers & Internet Experts
David Payne
David Payne
Are you an Oki Electric Industry Computer and Internet Expert? Answer questions, earn points and help others
