Question about Kenmore 73952 Gas Dryer
Our kenmore 697267 keeps tripping it's circuit every 5 minutes or so... what's the problem with it? Is it dangerous to just keep resetting it?
    President:
  • Kenmore Master
  • 2,651 Answers
Definatly a prob if tripping breaker every5 miin, resetting breaker is not good for either the breaker nor hte dryer, that would be hard to determine why without actually looking at though, i would probably calll someone to have a look at that one
Posted on May 03, 2008
Why does the circuit breaker keep tripping?
Need more information is it dryer,stove,ac ,heat, water heater,bathroom plug, garage plug ,outside plug, other
Lighting circuit with plugs
Oct 19, 2016 | Dryers
Apw keeps blowing circuit
It may be time for a new toaster, this one could be dangerous. It appers to be drawing lots of current, which would could mean a short inside and could cause a fire.
Aug 20, 2012 | APW Wyott XPRESS (120V) Conveyor Toaster
My Kenmore elite microwave is plugged into a surge protector and keep tripping the surge protector. I cannot use the microwave for more then a minute before it trips. Can you help
Your microwave is pulling more amps than the surge protector can handle. Remove the surge protector from the circuit and plug oven into wall outlet. Preferrably a GFCI circuit. Or you could puchase a surge protector with a higher amp tolerance.
Sep 04, 2011 | Microwave Ovens
The Reset button on cord keeps tripping, when turned on it works for a minute then trips again
There's obviously there is a short or electrical overheating problems omewhere in the appliance that's causing the circuit breaker (Reset Button) to trip. Stop using the AC unit and have it checked by a professional.
Feb 04, 2011 | Heating & Cooling
My Kenmore Ultrawash Quietguard Standard dishwasher won't start --or light up. I've checked the wall switch and circuit breaker and both seem okay. Darek Johnson darek_johnson@yahoo.com
Most dishwashers and other appliances using water, are protected by a Ground Fault Interrupter or GFI. These will sometimes trip without having detected any dangerous leakage current and others will get oversensitive causing them to trip well below their design current. A GFI wall socket will have two buttons on it; one to 'test' the other to reset. On some brands, when they are tripped, the reset button moves only a little further out and may not appear tripped. GFIs are also found combined with circuit breakers that also differ in appearance from the unprotected type and will also have a reset button. If your dishwasher is plugged in under the kitchen sink, check its appearance to see if it is GFI equipped.
BTW, these can be used in one location and connected so all of the wall plugs on the same circuit can be served by a single GFI equipped breaker so check any others nearby as well.
If a GFI refuses to stay set, it may be actually detecting some leakage current of a dangerous level so don't assume the GFI is bad, the appliance on it its circuit may have developed an internal problem.
Feb 02, 2011 | Kenmore Dishwashers
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
Dryer trips circuit breaker
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Dishwasher pops the circuit breaker
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Furnace keeps tripping circuit break
Furnace. To confirm use an Ampprobe or other brand ampmeter and see how much current is being drawn. If it is more that 80% of the breaker rating, it si for sure the Furnace.
Jan 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
Kenmore 73952 Gas Dryer Logo
196 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
