Question about Daewoo Refrigerators
Need mechanical thermostat for model no. wrx38rwh3 380 elite double door whirlpool refrigerator bought in 2002 made by daewoo
rickzilla
  • 706 Answers
SOURCE: Problem with ice maker
With your limited input , all I can do is suggest some things for you to try..
First off, are you sure you have water coming to the back of the fridge? No water, no ice. Secondly, Can you gain access to the ice tray inside the ice maker to see if it is frozen with excess water ? If it is, you may need to thaw it out to free it up to allow it to cycle. If no ice buildup is found....
Can you tell if the icemaker is actually cycling? If you listen, you can here the inlet valve open to let water in and then you should hear the motor that rotates the mold tray operate ( may take between 10 - 20 minutes so be patient) If you don't hear any motor activity duing this time.... You may have a defectice ice maker assembly and may need to replace it. Hope that helps...
Posted on Aug 07, 2008
  • 398 Answers
SOURCE: i want to purchase refrigerator which is best
single alot more organized a spacious, whirlpool has been ok here so far
Posted on Mar 07, 2009
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool refrigerator leaks inside
HI, First thing you do is remove the floor panel of the freezer. Do you see ice?
If there is ice, remove the rear wall of the freezer as well and start removing the ice. There will be down inside the drain hole also. A hair dryer works great for this project.
Please do not use sharp object/tools.
Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Thanks
Vic
Posted on Jun 20, 2009
aasc
  • 1606 Answers
SOURCE: Lights will not go out when I close Kenmore elite refrigerator
It sounds like the doors need adjusted so that when they close , the hit the light switch . Try loosening the top hinge screws , and even up the doors by the side view of the refrig . Re tighten the screws , and check to see if the lights go off . May have to try several times , to get it properly adjusted .
Posted on Oct 03, 2009
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
How to change temperature control on Whirlpool refriigerator?
There are many different models of Whirlpool Refrigerators and not all have the same temperature controls. Are you replacing the thermostat or a electronic digital controls? Look inside the door frame of the fresh food compartment on walls and door frame itself for the model number. JT3_5_2013_5_42_46_am.jpg
Mar 05, 2013 | Whirlpool Refrigerators
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I want to buy Whirlpool new proton series either 450 Ltr or 480 Ltr Delux model. Please inform me detail of Authorize dealer in Rajkot (Gujarat) with best price of each model. With Best Regards, SS...
i want to buy new proton Elite double door refridgerator 450 Lits., or professional Elite double door refridgerator 450 Lits., please inform MRP and offer rate at chennai (Tamil Nadu) engineersukumar@gmail.com
Jan 20, 2011 | Refrigerators
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
Refrigerator freezes everything even on low setting
Is it a single or double door? Assuming it is a double door. Normally the upper grade models have an auger motor that opens and closes electronically depending on temperature demand. This auger situated at the top LSD of the fridge normally freezes up due to various reasons. Most common is, product is placed to close to outlet which in turn creates a blow back effect and seizes the mechanism. Need to defrost fridge section for about 2 hours for ice to melt. Retry.
If it is a single door, your thermostat needs replacement. I'm taking it you have adjusted the settings higher(not so cold) but still not correct.
Sep 27, 2009 | Frigidaire FRS26R4A Side by Side...
The left door of the fridge was open all day.
Get me the model number and I will try to get you going,
model number will be like 213.89547 on front bottom frame
Thanks, Sea Breeze
Mar 19, 2009 | Kenmore 57029 Side by Side Refrigerator
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Black pearl fridge finish
Goo Gone made bt Magic american corporation it uses citrus to remove the tape.. for everyday use whirlpool makes an Appliance cleaner that work great..
Sep 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Daewoo Refrigerators Experts
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
