My alba lcd32880hdf turns on and after a few seconds the screen goes black .you can still hear the sound and all but you have a black screen
    Problem Solver:
  • 14 Answers
Sound and screen have different power circuits and protection fuses. If you are competent to can take the thing apart, if not get a technition to check it out. NO way do you have any electrical supply connected when you take things apart or even do not attempt to plug it in while the electrics are exposed. YOU COULD KILL YOURSELF AND OTHERS STANDING NEARBY
Posted on Aug 19, 2010
  • birdman92 Jan 07, 2011
    where are the fuses
Alba lcd32880hdf has lost colour when watching Tv but works when using games console
It is almost for sure a bad connection at you wires. To show in black and white means your red and green are reversed or bad. I am guessing you have this hooked up with component.
Jan 27, 2014 | Televison & Video
ALBA tv screen turns itself off, but the volume stays on, what's wrong with it? how do I correct it?
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
May 11, 2012 | Proton MM2701VT 27" TV
I set a parental control password on my alba lcd32880hdf 2 years ago and can't remember what it is. Can I reset it?
When you said this: They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
Jan 01, 2012 | Alba XJR 1300 SP Televison & Video
32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
May 07, 2011 | Televison & Video
Alba lcd32880hdf tv after a few seconds the pitcher gose off
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
Jan 07, 2011 | Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
552 people viewed this question
 Grubhead
Grubhead
