Question about LG WFT1071TP Top Load Washer
LG washer Model wf-t6517te not draining water
  • LG Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 19, 2010
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
LG model (WF-T1122TP) we are trying to wash all we getting PE what that means
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Dec 07, 2014 | LG Washing Machines
Lid open DE error in WF-T6517TE
This is lid magnet peice came out or lid assymble not fixing properway.
Mar 13, 2014 | LG Washing Machines
Wash a sheep skin cover now the machine will not drain water as it usually did...it is an LG WF-T7016PP
The hose from the tub to the pump or from the pump to the drain hose is blocked, remove and clear blockage.
Aug 19, 2013 | LG WFT1071TP Top Load Washer
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 25, 2010 | LG WFT1071TP Top Load Washer
My wf t1001tp wont drain...can anyone help?
sounds like a blocked drain hose or a faulty pump motor..If the machine can be drained by putting the drain hose lower than the water level then the hose is not blocked and it may be the pump...Make sure the hose leaves the machine from under the tub and not high on rear of washer. Obviously water won't flow uphill..If the pump has failed a new pump motor is much cheaper than buying a whole new pump....Nomess
Apr 04, 2010 | LG WFT1071TP Top Load Washer
LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
Lid open error in WF-T6517TE
it could be that the magnet in the door lid has slipped or fallen out. I stuck a new magnet on the rim of the machine and the dE eror message went away
Dec 13, 2009 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
1,478 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
