Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
I'm trying to dub old vcr tapes to dvd and need a way to get around the tape's copy protection system. Help?
  • 115 Answers
Strangely enough, the tape protection is more effective than the current dvd protection because it was analog. The tape is encoded with "bleeders" that distort the picture should you try to record it. You might be able to get a separate VCR and plug it into the dvd "in" as a work around. Also, you can buy used dvds of your favorite movies from Amazon for a few bucks each. Save yourself the time and headache and poor quality of that dubbing process.
Posted on Aug 19, 2010
Dubbing from VCR to DVD+RW, get: "This program is not allowed to be recorded"
Its likely a copy guard which to my knowledge cannot be gotten around.
May 25, 2012 | Televison & Video
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
I need to copya vhs to a dvd. Can you give the steps one by one please?
Can you provide the model of DVD/VCR player? Not all models do this.
For the ones that can, you need to use the Dub feature. Put a blank DVD (or one with sufficient space) in the DVD tray; initialize the disc if you are using a rewritable disc (RW). Then put the VHS tape into the VCR (you may want to break off the write protection tab). Then set the unit to VCR mode and forwared the tape to the desired recording point (copy-protected tapes can't be copied). Then some models have a dub or copy button on the unit and/or on the remote (press it and follow the onscreen prompts to select VCR to DVD, recording quality and press Enter to start). The copying will stop when you press Stop or run out of space on the DVD. On some models, you need to do this with the on-screen menus. For those, the look for a Dub feature (where it is will vary in the menus - usually in the same submenu as timed recording) and then select VCR to DVD and the rest.
I hope this helps.
(I'll be glad to provide more information if you provide a specific model. I've worked with several brands and there are some differences in the setup routine. My current unit is a Zenith with a Copy button on both the front panel and the remote.)
Dec 28, 2010 | Philips Magnavox DVD/VCR Dual Player
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
When I try dubbing from VCR to DVD the machine will only record about half of the VHS to the DVD. I get the following message...Recording Error - this program is not allowed to be recorded. The cause...
The DVD AGG (automatic gain control) is somehow being fooled into thinking the non-commercial tape has macrovision (copy protection). Is this a relatively inexpensive machine?
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't dub
It could be that the tape is copy protected. in that case, you're out of luck.
Aug 14, 2008 | Philips DVDR3320 DVD Recorder/VCR
Want to dub
Protected tapes cannot be copied to DVD on this machine.
The only way is to connect the VCR to a separate DVD recorder with a special cable to remove the Macrovision protection.
These cables were readily available on the internet, but I have no more details.
Mar 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia IS-DVD100121
thisCD recorder wont DUB COPY PROTECTED MATERIALS (COPY RIGHTED) AS IT WILL RECORD HOMEMADE VIDEO FROM A VIDEO CAMERA BUT NOT FROM A STORE BOUGHT TAPE AS THEy ARE COPY PROTECTED.
Dec 31, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
