Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
A long moaning sound but not working water not draining
  • Ace Hardware Master
  • 43,501 Answers
You have something jamming your disposal...this will not let the motor run...
Here is a tip that will give you some ideas about what you need to do to get it working again...
Garbage Disposal Clogged or Jammed
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
heatman101
Posted on Aug 19, 2010
Moaning sound from front drivers side
sound like wheel bearing if car in motion.moaning while vechicle sitting still could be power steering pump or water pump bearing going bad.alternator with bad bearing cause moaning noise.
Dec 28, 2012 | 2005 GMC Envoy Xl
I have kenmore elite 665.1342 works but do not drain
f the washer will not drain then it most likely will not spin so the first problem to check is the not draining problem. The first thing to do is remove the lower access panel and check the drain pump. During the drain cycle does the motor hum or moan? There is a drain filter that can be removed and checked. See the image below for more on this. Have a shallow pan or towel ready for the water that will leak.
You do not give a lot of details but if the washer will agitate then the door switch and motor are most likely okay.
Once the drain pump is working then see if the washer will spin.
If the washer drains and does not spin thin you should see an error code indicating what the control thinks is the problem.
I hope this helps. You can reply with any additional details or questions for further assistance.
Oct 20, 2011 | Samsung Dishwashers
Washer won't drain and some cycles won't work
Make sure your drain hose is at least 2ft off the ground if your drain pipe is to low it wont drain
Feb 18, 2010 | Fisher Paykel EcoSmart GWL15
GE Model GSS22JERFBB moaning sound form freezer section
That's the fan motor. Either the fan blade is hitting something or the motor is going bad. Either is a cheap fix.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Moaning noise when I turn left or right in my 2002 VW Passat
Your power steering pump has gone bad. Consider replacing it. I had the same problem before.
It moans when u turn at a stand still but rolls freely when in motion?
Rate this fixya
Mar 24, 2009 | 2002 Volkswagen Passat
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Moaning noise in steering column
The probably lubed the intermediat shaft conenction. The loud poping noise could be from them not sitting the boot back correctly. Inspect your boot. As for the moaning noise Only thing I can think of is a hydraulic noise.
Dec 11, 2008 | 2007 Saturn Outlook
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Washer
There is a thin tube going from the control to the drain area near the exit of your machine... this tube is likely to be clogged. Remove the clog & to check blow into it to see that it is free, refit.
Aug 04, 2007 | GE Profile Prodigy WPSE4200A
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
302 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
