Question about Microwave Ovens
Simac IL machine has a timer that is not functioning. How best to get this fixed? Thanks
  • Microwave Ovens Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 19, 2010
Maytag microwave oven does not heat up using timer; works OK otherwise
If you wish to get some details microwave oven repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 18, 2016 | Maytag Microwave Ovens
Microonde whirpool jt359 err3
Percio il ventola sono rotto. Avete il manuale di Micro? Guarda che cosa rotto quando avete il Err3.
Jun 11, 2014 | Microwave Ovens
Jvm1350 micro wave will not turn but timer does
follow this steps and fix it.God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2hz2qmlJ9
Oct 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
My simac ice cream maker needs to be reactivated
Hi, what is the model of your simac ice cream maker ?
Thanks
Sep 16, 2011 | Microwave Ovens
Microwave works but does not cook (does not heat up). Everything else seems to work properly.
hello,
what this means is that there have been a disconnection on the wire of the element (heater)
what you need to do to fix up the problem is to unscrew the oven then trace the wire down to the element power point and fix it back to it position
please make sure all form of power supply is OFF when carry out this function
Good lock and thanks for using fixya.
Jun 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
Are microwave safe egg poachers doing damage to microwave?
you are not supposed to have any metal in the microwaves for cooking something , as why the other two quit , that is probably why they quit so soon
there is some more exspensive microwaves that can work even when metal is used inside( but these are special types of microwves)
Nov 10, 2008 | Danby DMW1153 Microwave Oven
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
