Question about Legacy Audio American Legacy II LA890 Car Audio Amplifier
No power in my amp
I have good power goin to my amp but it wont turn on. i need a diagram so i can check the resistors and all that. tha amp is a legacy LA790. please help
  • 631 Answers
If you are going to try to repair this yourself and can't find a schematic diagram, read the following page. It should help you through basic troubleshooting.
Amplifier Repair Primer
If you have questions, let me know.
Posted on May 03, 2008
2002 jeep grand cherokee heater fan wont turn on when you turn the dial.
Do you know how to test automotive electrical circuit's , looking at a wiring diagram so you know what all is involved in the blower motor circuit . Using a DVOM - digital volt ohm meter to test the circuit . Free wiring diagram's here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click HVAC ,then under subsystem click on HVAC controls . Click the search button then the blue link .The thing's that could be wrong , blower motor it's self , the blower motor controller for automatic climate control , a blown fuse -but fuse's don't just blow for no reason - short to ground maybe ! 40 amp fuse #1 in the under hood fuse box . Blower motor resistor block if your vehicle has manual climate control .
Test And Replace Blower Motor Resistor Chrysler Town Country Caravan
Nov 08, 2017 | Jeep Cars & Trucks
Have a kenwood KAC-8101D and found a burnt resistor at R101 brown gren brown gold.. The blue power light turns on indicating power but no sound comes out anyone know what else is fried or what else to...
without a diagram, and the exact location of the resistor in the amp, it is almost impossible to say if anything else is defect. Most of the time, a burned resistor, if it is defect, it had to much current, so the transistor (alone or in a IC) got to much and perhaps also died.
If you don't have the skills, tools and diagram (service manual) don't start it, you end up with something that does not amplify anything.
Jun 10, 2014 | Car Audio & Video
Chevy astro
2 fuses to check, Kevin: in the instrument panel fuse block, 20 amp fuse #12, Htr-A/C. In the under hood fuse block, Frt HVAC fuse, 30 amp.
The new resistor you put in, was it called a "Blower Motor Resistor and Relay Pack" ? It appears there is a relay there with the resistor, but appears to only be used with htr on high speed. However the low speed wiring is also routed through this relay. If it was the Pack you put in, guess that is not an issue.
In the Heater and A/C Control Module is the blower switch. The power in to the control module is a brown wire (from the #12 fuse in instr. panel). With key on should be hot. It appears the brown wire goes to the mode switch and then to the blower switch. Check for power in, and check continuity of both switches. Or check if blower switch has power to it, then check for continuity in it-it should have continuity in all speeds.
If all is good so far, you need to check if blower motor ground is good.
Here can be found a wiring diagram for your Astro. Look for heater controls under the system called "HVAC". Every wiring diagram and TSB for the Astro (or any make, model) can be found here:
Good luck.
Jan 04, 2014 | Cars & Trucks
15 amp fuse blows and no running lights. What's wrong?
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Apr 06, 2012 | 2006 Harley Davidson FLHX Street Glide
I have kikcer amp 1500.1 is workin good for one year whith 4 memphis 15'' and one day just goin in the protection mode when i turn the radio up can you help me please
sounds like your amplifier does not have the power that your subs need check the rms out put on your amplifier and check how much rms your subs can handle if your amplifier has less rms power then your subs theirs probaly your problem that what happens when it kicks in to protection you could in up fring your out put chips in your amplifier not trying to say that the problem but check your rms power make sure the amp and subs can handle the same power
Oct 31, 2009 | Car Audio & Video
Heater &air wont work
Resistor , check it out. Conect power to the motor direct , see if it rotates. Hot wire it with a fuse and a swich through the resistor for different speeds. It will be manual not auto unless you want to change the module. Re calibrate the vent doors , and do a diagnostic if you have tha auto modul . Vitally
Jul 02, 2009 | 1996 Chevrolet Astro
Front audio channel burnout
Resistors can fail from being turned up to hire, wires getting bumped together or against metal, speakers being wrong ohms, or just plainly overheating.
May 22, 2009 | Harman Kardon HKTS 5 System
Blower motor wont run has power to motor
that little black box is tha heater resistor block. power goes into it and comes out the different speeds what ever the switch is turned to. it sounds like all the resistor coils inside the block have blown, quite common on all cars.just to make sure the motor is still ok follow the cables that go from the block into the motor , only 2 put power on one of them and earth out the other one and the motor should run at full speed . if it does change the resistor block and all the speeds should then work. hope this helps.
May 02, 2009 | 2003 GMC Envoy Xl
Hitachi 57uwx20 b h/d rear projection..... turns on for 5 seconds with a red only screen will display menu screens but also tinted red then shuts off power. amy idear on what to check , look for , test?
Check convergence Amp Stage.
Your problem in one of the IC and couple of Small Value Resistor.
Dont Forget to Rate!
Good luck
Dals123
Oct 17, 2008 | Televison & Video
Legacy Audio American Legacy II LA890 Car Audio Amplifier Logo
250 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
