Question about Bowflex Treadclimber
I have put together my Bowflex Treadclimber and am now trying to calibrate it. Every time so far (over two days) I have gotten "Calibration Fail." This Failure occurs even though what the Treadclimber does each time has been a little different. The red grommet into which the speed sensor is inserted is touching the inside of the pully wheel. I have tried and tried to get it a "credit card thickness" away from the pulley wheel, but when it arrived it was up against the pully wheel and I just have been unable to get it "backed off" from the wheel. Just cannot get in there to do it. Can you please help? Dave
    Problem Solver:
  • 4 Answers
Have you tried customer support at Treadclimber.com?
Posted on Sep 03, 2010
After trying to cal my tc5000, I got a cal fail. I then pulled the saftey key and re-inserted it and it displayed boot clr
adjust the REED swtch, and speed sensor, test it, clean it, and tight the plug or connector.
2) Tight the upper cable vs lower cable
3) Tight the ribbon cable for keypads
4) Run again the s. calibration.
God bless you
Nov 16, 2012 | Bowflex Treadclimber
Bowflex treadclimber gives error code h13 h24
this a problem with a bad design from a factory. You must call to service support a explain this error. Is a problem,with a PROM AND EPROM.
However you can try to RUN the software calibration for diagnose, and troubleshootingl.
God bless you
May 09, 2012 | Bowflex Treadclimber
Calibration
Dear Sir:
1)See the attached diagram for Reed switch , clean, tigh the connector very well.
Read carefully your instruction manual for software calibration for diagnose +trouble.
If you do not have go to the next web and download for free: www. fitness. manualsonline. com
sincerely. God bless you.
Apr 19, 2012 | Bowflex Treadclimber
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
Can't get Bowflex TreadClimber TC5000 to pass calibration.
DEAR
AT FIRST YOU MUST REMOVE COVER AND SEE CAREFULLY TO FIND SENSORS SOME SENSORS ARE PHOTO SENSOR AND GET ON DUST AND CAN NOT GOOD WORK THEN BETTER THIS IS YOU CLEAN DUST VERY VERY GOOD PERHAPS SOLVE YOUR PROBLEM.
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 29, 2017 | Bowflex Treadclimber
Bowflex Treadclimber Calibration Failed
Check the wire connection at the bottom of the right upright. Male Female white connectors. if they are good then check speed sensor under the left rear treadle. Must be about credit card distance from drive pulley. Remove rear covers to access. Note you will have to remove both side covers and back cover. 10 Screws.
Jun 23, 2009 | Bowflex Treadclimber
Calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Jun 03, 2009 | Bowflex Treadclimber
The machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Mar 18, 2009 | Bowflex Treadclimber
Calibration Failed
make sure speed sensor isnt to far away from left wheel or did not get unplugged from circut board
Dec 25, 2008 | Bowflex TC3000 Treadclimber
My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Dec 07, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
444 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
