Question about Samsung Microwave Ovens
Hy i own a samsung microwave oven . for the past few days the keypad is not responding? what to do?
  • Samsung Master
  • 43,501 Answers
The keypad needs to be replaced...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 19, 2010
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Having an issue with the keypad - not responding
I would contact Samsung, they seem to be aware of the issue with the control panel failing on there otr model and are replacing them free of charge under there "epidemic warranty"
May 06, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Se code
Contact Samsung for the SE error message. They are fixing my microwave for free today even though it is 4 years old. Model #SMH9187ST.
Feb 22, 2013 | Samsung SMH7178STD Microwave Oven
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Sep 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Samsung household microwave oven model # SMH8165ST that when plugged in will beep a few times then blink "SE". None of the buttons will work.
Try calling Samsung....
Purchased samsung SMH8165ST in Oct 2009. have had the SE code problem for a few month now. Resetting worked at first. Then the light started flasing on & off along with the beeping...would not reset. Out of frustration I called Samsung. I was told they are aware of the problem & would repair in the "epidemic warranty". Repair man just left. It took him about 15 minutes to change out the keypad. No charge!!
Aug 30, 2011 | Samsung SMH8165STE Microwave Oven
Samsung microwave has numbers on the display but keypad doesnt respond
It's probably a defective membrane keypad.
But without the full model number with suffix, we can;t give you an estimate and let you know your options.
Please post a new help request with the full model and symptoms.
Jul 02, 2011 | Samsung Microwave Ovens
Keypad not responding
there may be a circuit problem in the keypad.
need to contact the samsung microwave service centre.
Jun 23, 2009 | Samsung MW1030WA Microwave Oven
MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
Apr 04, 2007 | Samsung MW1080STA Microwave Oven
Microwave Ovens Logo
566 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
