Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Hello, i have a d52w20byx1 d483c30p4 my problem is i have great picture but NO sound, ive tried flipping the switch in the back, ive went to the menu to see if the speakers were turned off, ive done everything i csn think of, i still cant get any sound. im wondering if the little board in the back where the speakers hook up to is bad? is there any way i can tell if it is bad and can it be fixed? Thanks for your time!
Slinteriors
  • 8617 Answers
SOURCE: rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
http://servicemanuals.vstore.ca/
Posted on Jun 26, 2008
SOURCE: convergence nightmare
I had the same problem, I resoldered the fyback (LL008) and changed the fuse (FL231) had my voltage back, but still no convergence. I read in the service manual that disconnecting BW001 BW002 on the Converagence Amplifier board may remove the load on the Convergence Power Supply. I unpluged the TV did remove it and turned the TV on, let it boot up and run for two minutes or more, then shut it down, waited a few minutes. Unpluged TV and I pluged back in BW001 and BW002 connector back in and turned the TV back on and it was back. Some adjustment and had had a great picture back. If this done do it your out of luck, the Convergence Power Supply and Convergence Amplifer Boards are no longer avialable. Make sure that all the flyback leads are resoldered real good.
Posted on Aug 16, 2008
ladywinn
  • 5138 Answers
SOURCE: I HAVE A RCA SCENIUM HD52W69DYX33 ONLY PROBLEM
You have a open FUSE fl231 it will be located on right side of FBT flyback transfomer there is 3 in a roll --small brown rectrangler looking caps it will be the one in the middle fuse they like like capacitors but are fuses.Let me know if this helps.also with TV off press and hold at same time vol- ch- on front of tv untill it comes on then release buttons.
Posted on Jul 24, 2009
  • 67 Answers
SOURCE: RCA Projection tv has great picture but no sound. Model #P60812BL
normaly the audio ics go bad cap or 2 make sure audio sing is present on input of aud ic if so chk opt if opt bad replace ic and capacitors around ic good luck this should fix ur prob parts nte semiconductor.com 25.00$
Posted on Aug 30, 2009
ladywinn
  • 5138 Answers
SOURCE: R56WH76 Failed Convergence Fix
OK on same circuit board as fuse up on the front part of board look at capacitor cp150 if it is swollen or puffed up it is bad 2200uf 16v use 25v and replace 2 other capacitors in same area cp114 cp120 220uf 35v.
Posted on Sep 24, 2009
The power went out and when it came back on our stove is not working. No lights on the display. The stove is dead. Is there a way to reset the oven???
Did you trip a breaker. Try to flip the breaker switch that goes to the oven. You may have to flip all the switches and flip them back on to get the correct breaker switch.
Jun 14, 2017 | Kitchen Ranges
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
When i try to turn the tv on it does it just clicks over and over
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 21, 2011 | Proscan 55LC55S240V87 55 in LCD TV
Hi my name is Robert I have an rca 52inch tv model# d52w20byx1. The tv gets power no picture or sound. Can you give any suggestions
jaxff85,
I certainly can. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting process and help you pinpoint the problem.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Xbox 360 has sound but no Picture
This happened to my first 360, and in my case, it was a hardware failure. You can call Microsoft and hope your warranty is still good, and they'll fix it free of charge, but if its not, then you have to pay a fee.
Mar 26, 2009 | Microsoft Xbox 360 Console
32" Orion LCD TV Model TV-32082C Hello.Hopefully someone could give me an insight to my problem. Switched my TV on this morning and i have a black screen but with vertical grey bars on it. Switch off...
it sounds like a couple of you capasiters went out they are located on each corner of the tv if they are popped up then they need replaced as they are supposed to be flat on top
Nov 04, 2008 | Televison & Video
Not truning on
I would check your breakers again your oven breaker is a double one .. one of them may not be turned back on...
Apr 17, 2008 | Frigidaire FEF355 Electric Kitchen Range
Stressing out!!
Alba TVs are manufactured in Albainia and the service info is next to impssible to obtain. I would try to troublehoot the deflection circuits. Possibly horizontal output or one of the regulators.
Feb 26, 2008 | LCDDigital LCD7 Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
