Question about Texas Instruments TI-83 Plus Calculator
It drains batteries in a day on or off - Texas Instruments TI-83 Plus Calculator
    Problem Solver:
  • 14 Answers
You need to update your operating system. Let me know if that helps.
Posted on Aug 20, 2010
New battery keeps draining. Don't know what is going on. It's a 2001 ford explorer sport 4.0 l.
Starter and alternator are the most likely culprits(one day). Interior lights and radio will also cause this. But usually takes a couple days to drain the battery.
Jul 24, 2015 | Ford Cars & Trucks
05 Cadillac SRX battery draining down after a couple days of sitting.
Dealer should have been able to figure this one out!
Best bet to trouble shoot is next time it is going to sit for a couple of days disconnect the battery. After the couple of days pass hook up the battery and if it's dead then the battery isn't holding a charge, if not then something in the vehicle is draining the battery.
If you live in a colder climate weak batteries tend to be more of a problem as temps get colder.
If the battery is more then 3 years old it is a prime suspect.
Hope this helps!
Dec 06, 2013 | Cadillac SRX Cars & Trucks
Fuse 8 on 1990 allante is drawing down the battery. will completly drain battery in 2 days
Have you checked BCM input parameter BI61? That is the most common cause of the 2-3 day battery drain. Have you tried pulling fuse #8 under the ash tray for the CPS to see if that stops the drain? You can pull one of the plugs off the AC blower control module to isolate that. If you can not hear the blower motor running with the key off, that probably is not an issue.
Sep 05, 2012 | 1990 Cadillac Allante
Battery drains if not used for 2 days.
heater resistor's cause battery drains and air con operate incorrectly.
Apr 07, 2010 | 2001 BMW 5 Series
The battery in my car keeps draining. takes about a day or so to drain. it's not the alternator
Sometimes the battery itself is the problem. The quality and age plays a big role. Best way to test is to disconnect the battery cables from the battery after your done using the car. Then a day or so, hook the battery back up and then see if the problem still occurs.
If the battery drained, you'll know the battery itself is the problem.
Oct 06, 2009 | 1991 Toyota Camry
1998 Corvette drains the battery in less than 2 days.
No, corrosion will not cause a battery to drain, even if the corrosion is on the terminals. Several factors can cause battery drain, I would first have the battery tested to see if the battery it self is not bad. If the battery is good, then the most common is a short. All most all new cars have a certain amount of drain,(measured in milivolts) this drain is for clocks and computer memory's, and it would take several days of a vehicle sitting for the battery to be drained. Don't immediately assume you have a problem if you see 2-6 milivolts of drain on a battery with the key out, now if your battery is being drained after being parked over night, you have a problem. The easiest way to pin down the problem short is to disconnect your positive battery cable from the battery, take a 12 volt test light and clamp one end to the positive cable, and hold the probe to the positive post. Now if you have a short the light will come on. Have someone help you by pulling the fuses one at a time. If when a fuse is pulled the light goes out you have isolated the short to that system. If you pulled all the fuses and the light never went out try disconnecting all the wires from the alternator, 9 times outta 10 do this will let you know where your short is. If the system is not critical like power locks some people just leave the fuse out.
Mar 05, 2009 | 1998 Chevrolet Corvette
Texas Instruments TI-83 Plus Calculator Logo
81 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
