Question about NRS Hoveround MPV 5 - Used Power Wheelchair
The speed control light goes back and fourth on the console.
  • 692 Answers
If the lights are chasing left to right then you are in inhibit mode meaning a charger is attached or there is a problem in the joystick with the inhibit functio. Right to left chasing I think means you are in freewheel. Turn the Power off and reset the levers in front on the chair then turn the power back on and hope the lights are steady and the chair will work. If this doesn't do it maybe you are in lockout mode. If you have the manual for this chair it should explain how to get out of "lockout". If not try turning the power on and within 10 seconds push the joystick straight forward and hold until you hear a beep then immediately move the joystick to the rear and hold until you hear another beep then release joystick to the center. This should get it out of "lockout" Hope this helps!!! Of course you could always call Hoveround and ask for tech support to help with this. Checkout their website for phone number Hoveround.com
Posted on Aug 19, 2010
When I put my 1993 toyota tazz in first gear I have to ref it high to pull away , it goes slowly when I ref it and then pick up speed , the same in second , third and fourth gear.
feed signal from the throttle sensor i would think to be the problem this reads the input for the engine speed and, it could be the sensor or the connection to the gearbox control unit. as its still getting a signal but its reduced, check and clean the connections,
Jul 10, 2017 | Toyota Cars & Trucks
I have a 1995 Buick Century 6 cyl. The transmission shifts smoothly and into 4th gear but when I get to about 55 mph it shifts back into 3rd gear by itself and won't go back into 4th gear. What is...
Fourth gear in your vehicle doesn't exist. What feels like a fourth gear is the torque converter locking up. The lockup lockup is controlled by a solenoid in the side pan of the transmission, and the solenoid is controlled by the ECM (electronic control module) in response to several pressure, temperature and speed sensors etc. To determine which component is the problem you'll need a professional transmission mechanic with the proper diagnostic equipment.
Jun 28, 2011 | 1995 Buick Century
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
My controller just shows all four lights flashing and when i try to sync it, the lights just keep spinning round and does'nt connect
Jun 03, 2010 | Microsoft Xbox 360 Controller
I have an xbox360 and it has a red light in the fourth player slot
E68 error message? If so, turn off system, take off hard drive, put hard drive back on, turn system back on.
Feb 19, 2010 | Microsoft Xbox 360 Pro System Console
The top screen s really loose and flips back anf fourth
Try buying a tri screwdriver on ebay and using this guide: www.youtube.com/watch?v=vRzTgfo2PsM then take it apart and use some glue.
Apr 17, 2009 | Nintendo DS Lite Console
Wii Controller
PRESS THE RED BUTTON INSIDE THE BATTERY COVER OF THE REMOTE. THEN PRSS THE RED BUTTON INSIDE THE COVER AT THE FRONT OF THE WII. DO THIS AT THE WII MENU
Apr 09, 2009 | Nintendo Wii Console
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
152 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
