Question about Cycling
What is the correct way to shift this model bike? I have been given one and I have tried every way that I can think of and I can't get it to the front top sprocket?
    Problem Solver:
  • 14 Answers
  • It sounds like there is not enough cable tension for your front shifter or the shifter cable has stretched.
  • METHOD 1: on the shifter (where the cable housing attaches), there should be a barrel adjuster. Turn the outermost portion of the barrel adjuster so that the shifter cable gets tighter.
  • METHOD 2: unclamp the cable at the forward derailleur and manually pull on the cable until it is tight and re secure the cable. Then follow METHOD 1
Posted on Aug 19, 2010
1984yamaha virago 1000. with the bike running, when I try to shift from neutral to first gear the bike stalls. I think it has something to do with the electrical.. Help!
If you are at idle, in neutral, with the clutch lever pulled all the way in, and you shift into gear and the engine dies, it is likely the switch at the clutch lever. When they fail the bike does not get the signal that the clutch is disengaged and it is safe to shift into gear. Have that switch checked. Some bikes also have a side stand switch, make sure your side stand is always up before putting you bike into gear.
MGM
Sep 13, 2013 | Yamaha Motorcycles
Bike starts but as soon as u engage gear shift it stalls bike
Does this model have a switch on the side stand. If so it could be faulty and fooling the bike into thinking the side stand is down and stalling it for safety.
Sep 16, 2011 | 2005 Hyosung GT 650 R
IJust bought a 2009 Motobecane Cafe Latte Hybrid bike used. The previous owner hardly used the bike and it looks new. He stated the bike probably need a tune up and the front derailleur was skipping the...
The derailleur has to be properly aligned to the chainwheels, then adjusted properly. A new cable must be installed correctly so that there is not excess friction, and then given the right tension. If that is done then the problem may be the shifter. If when you shift from the large chainwheel a single click sends it to the smallest then the shifter is possibly broken. You can try squirting wd-40 or similar into it to see if it's gummed up.
Mar 18, 2017 | Motobecane Cafe Latte
My dahon p8 i think is slipping gears, when i put in 7 today it's fine for a second then it's feels like i'm in 1. i tried to shift to various gears while riding to see if that would magically correct it...
"Feels like" it shifted or did it actually shift??? If NOT the latter maybe your brakes are rubbing. Analyze. Or maybe the shifter is moving. Or the shifter cable is not gliding smoothly in the cable housing.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Apr 29, 2011 | Dahon 09 Mu P8 Folding Bicycle
The front suspension is messed up and i dont know how to deal with it? right now its said to be in first gear but the chain is in 2nd and once i change it to 2nd gear the chain ends up being on the 3rd...
I think you might be confusing some terminology.
The Front "suspension" is the fork assembly that holds your front wheel and goes up and down. The shock absorber or suspension.
The part in the middle of the bike that the chain changes between 1,2 and 3 gears is the crankset and relates to the front shifting. The shiftlever on the left of the handlebars would be the part that indicates the 1, 2 or 3 numbers.
To get the front derailleur (changer) to shift into the proper gears the cable must be under the correct tension and limit stops adjusted correctly. Shift the lever into the #1 position and check the cable tension. is it very loose? can you wiggle it easily side to side or up and down? if yes, then you need to tighten the cable by loosening the bolt at cables attachment of the derailleur and then pulling out the slack, tighten the bolt again and check your shifting . If that does not work then take the bike into a bike shop and have them look at it, something too difficult to explain may be happening.
Apr 21, 2011 | Mongoose Exile 26 Men's Full-Suspension...
I really don't have a problem. I'm a new rider and what I've been told by other experience riders is the normal 5 speed shift sequence is 1st is all the way down 2nd is up past neutral, then 3rd, 4th and...
The correct information should be in the owners manual, the person selling the bike should be able to tell you the correct sequence, and most modern motorcycles have the shift pattern imprinted in tiny raised pictures on the case right next to the shifter. I am pretty sure Suzuki and some British bikes used down 4 patterns in the late sixties . Your friends may be pulling your leg. I would bet money that the boulevard uses a down 1 up 4 shift pattern standard to most models on the market today.
Aug 19, 2010 | Suzuki Boulevard M50 Motorcycles
Exercise bike is not displaying correct feedback
What do you mean it s not displying correctly?
May 03, 2010 | Exercise & Fitness
Wont shift into 2nd
First, with the bike not running, rock the bike back and forth and try to shift the gears. You should be able to shift up through all the gears and back down. If you can't, the problem is in the shifting mechanism. They've had some shifter pawl problems on earlier models. You'll have to pull the primary cover to get to the shifting mechanism.
Next, put the bike in first gear with the engine off. Now, pull the clutch in and try to start the engine. If the bike lurches forward, you're problem is the clutch. Check the adjustment of the clutch according to the service manual.
Sep 23, 2009 | 2005 Harley Davidson XL 883L Sportster
Will not shift down
This doesn't sound like bent shift forks. That is a very good thing. If the gearbox has to be opened you would be looking at $1500 to $2000. Checking and fixing it yourself as follows might cost you $20. A dealer would charge $100 to $200 or so. Remove the right side casing and then the clutch. I think you will find a broken gearshift return spring #13 or pin #14, gearshift drum stopper spring #10, or gear shift arm spring #12. Any of these parts can be supplied by Babbitt's. Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Look at "GEARSHIFT DRUM" page. I sincerely hope I am correct in the diagnosis. The dealer route really hurts the wallet. Let me know what you find out.
Jun 12, 2009 | 1984 Honda VT 500 C Shadow
Shift Bicycle Gears
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Oct 29, 2008 | GMC Denali 700C Road Bike
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
