Question about Whirlpool LER4634J Electric Dryer
I have a LER4624BQO it was working fine then for the second load it hums when I press the button but it wont start or anything. Checked breaker to the fuse in the house and that looks fine. Could it be the heating fuss inside the unit?
  • Whirlpool Master
  • 2,605 Answers
Hello, welcome to FixYa.
Based on your description ( "the second load it hums when I press the button but it wont start or anything" ) it certainly sounds like a faulty motor.
Try running the unit empty and see if you experience the same symptom after a 60min timed dry cycle.
If it hums when pushing the start button this indicates the motor is receiving the "start command" but cannot, likely due to overheating from poor ventilation and even if the vent is corrected it`s likely irreversibly damaged.
The motor part # is 279827 and will look like this...
This can also be caused by a large amount of lint built up around the motor which prevents it from cooling proper.
Here`s a helpful link for Whirlpool dryer repairs which may help in the "how to" department so you can go in yourself and try cleaning it and what to look for etc.
http://www.youtube.com/watch?v=14M_A6Wd9XA&feature=related
Let me know how you make out or if you require further assistance.
Good luck.
macmarkus :)
Posted on Aug 19, 2010
Built in washer drier wont start
What brand and model? Turn off the washer/dryer breaker, wait 15 seconds, then turn on (reset) the breaker.
Jan 19, 2012 | Neff Washing Machines
WHIRLPOOL dryer model JLDE8300N1 WORKED FINE, NOW WHEN PUSH START BUTTON, JUST GET A HUM. I have reset the breakers in the house. plus removed the top of the dryer & back to see if anything looked...
Sounds like something not leting the motor turn. Perhaps something in the fan i've seen pencils
nails or almost anything . Check for frozen rollers or belt pully. Last check motor , the bearing may be bad. Sounds like may be motor. Hope this helps
Jul 18, 2011 | Dryers
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer quit working - will not do anything when "start" button is pressed
It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
May 12, 2009 | Dryers
Comressor won't kick in...
Check contactor on outside unit for burned contacts. Try to manually press the contactor with INSULATED screwdriver to test. Should be some **** on cotact buttons. Hope this helps. Let me know. Good luck
Apr 27, 2009 | Heating & Cooling
Power is on but wont wash or anything only hums when i press start
the buzz or hmmm noise is probably coming form a clogged drain pump assy, something has gotten into it and is preventing normal operation. youll need to remove the lower acess panel (2 screws aong hte bottom of the front of unit) from there youll gain acess to the drain pump in the rught front corner, pull off the hoses and check for obstructions, even look within the white pump impeller housin gas well. UNPLUG UNIT FIRST!!!!ALWAYS LIVE WIRES TO DRAIN PUMP ASSY
Nov 04, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
