Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
The pump go on and dont off - Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
  • 43,501 Answers
The pump is not building enough pressre to cut the pressure switch off...
Checkout this tip and the links to other tips at the bottom of it to get the info you need...
Jet Well Pump Well Jet Water Pump
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
heatman101
Posted on Aug 19, 2010
I cant find the mian power wire to my fuel pump
Remove the fuel pump relay & jump it- to turn on the fuel pump
Feb 21, 2013 | 2000 Ford Focus
New fuel pump won't run
I have had bad pumps rite out of the box but dont assume its a bad pump check for power at the pump with a test lite remember the pump only has power for 10 or so seconds after key is on if vehicle dont start pump will lose power until key is turned off then you have to turn key back on best if done with 2 people
Jun 07, 2012 | 1994 Ford Econoline
Mercedes 1998 c230 water pump replacement
REPLACE WATER ALL YOU NEED TO DO IS DRAIN THE COOLANT SYSTEM.REMOVE THE ENGINE COOLING FAN AND CLUTCH THEN THE FAN SHROUD.REMOVE ENGINE COVER IF EQUIPPED.THEN REMOVE THE ACCESSORY DRIVE BELT.UNBOLT THE POWER STEERING PUMP MOVE IT ASIDE DONT DISCONNECT ANY POWER STEERING PUMP HOSES.DISCONNECT WATER PUMP HOSES, REMOVE BELT PULLEY THEN REMOVE WATER PUMP MOUNTING BOLTS AND WATER PUMP.CLEAN WATER PUMP MATING SURFACE BE CAREFUL DONT SCRATCH PUMP SURFACE. BESURE WHEN YOU INSTALL NEW WATER PUMP USE GASKET SEALANT ON BOTH SIDE OF GASKET TO KEEP IT FROM LEAKING COOLANT.
Sep 26, 2011 | 2007 Mercedes-Benz C230 Sedan
The rear water pump does not pump water onto the windscreen I dont have the owners manual and dont know how to fill this rear tank up or if it runs thru from the front one
Auto Scaner The rear water pump does not pump water onto the windscreen I dont have the owners manual and dont know how to fill this rear tank up or if it runs thru from the front one
Mar 22, 2011 | 2005 Toyota ECHO
Changeing a power steering pump
CHANGING POWER STEERING PUMP YOU HAVE TO PLACE A DRAIN PAN UNDER THE VECHICLE. SIPHON OUT POWER STEERING FLUID WITH A SIPHONER DONT USE YOUR MOUTH TO SIPHON SWALLOWING POWER STEERING FLUID CAN BE FATAL MAKE YOU SICK.WHEN ALL POWER STEERING FLUID IS REMOVED FROM POWER STEERING PUMP.REMOVE DRIVE BELT.THEN REMOVE THE POWER STEERING PUMP.THEN YOU HAVE TO REMOVE THE POWER STEERING PUMP PULLEY THE NEW POWER STEERING PUMP DONT HAVE A PULLEY YOU HAVE TO HAVE REMOVE PULLEY FROM THE OLD POWER STEERING PUMP.YOU NEED A PUMP PULLEY REMOVER AND A PULLEY INSTALLER.YOU CAN TAKE OLD POWER STEERING PUMP AND NEW POWER STEERING PUMP TO A MACHINE SHOP.THEY WILL REMOVE PULLEY OFF OLD PUMP PRESS IT ON NEW POWER STEERING PUMP.THAT WOULD BE CHEAPER THAN BUYING THE PULLER AND INSTALLER.GO TO AUTO PARTS STORE BUY NEW HIGH PRESSURE LINE O RING GOES TO PRESSURE LINE GOING INTO POWER STEERING PUMP.ONCE YOU GET NEW PUMP READY PULLEY BEEN PRESSED ON.TAKE POWER STEERING PUMP HOME PUT IT ON. BLEED POWER STEERING SYSTEM.WHAT YOU DO WHEN YOU GET NEW PUMP INSTALLED HIGH PRESSURE LINE IN PLACE.PUMP BOLTED IN DRIVE BELT ON POUR POWER STEERING FLUID IN POWER STEERING PUMP UNTIL FLUID LEVEL STOP DROPPING AND YOUR LEVEL ON POWER STEERING DIP STICK AT COLD LEVEL.NOW START CAR UP LET IT IDLE FOR 3 MINUTES.THEN TURN OFF ENGINE CHECK POWER STEERING FLUID IF FLUID LEVEL DROP ADD LITTLE MORE UNTIL LEVEL ON DIP STICK ON COLD MARK DONT OVER FILL.NOW SAFELY RAISE SUPPORT FRONT OF VECHICLE. START THE ENGINE.TURN STEERING WHEEL FROM ALL THE WAY FROM LEFT TO RIGHT DONT STOP LOCK WHEEL .GO LEFT TO RIGHT SEVERAL TIMES.THEN TURN OFF ENGINE CHECK FLUID LEVEL.IF ALL IS GOOD LET VECHICLE BACK DOWN LET IT SIT FOR A WHILE CHECK FLUID AGAIN.DONT DRIVE VECHICLE IF POWER STEERING PUMP MAKE NOISES OR YOUR STEERING FEEL STIFF HARD TO TURN.JUST MAKE SURE FLUID LEVEL RIGHT AND DRIVE BELT TIGHT GOOD LUCK.
Nov 02, 2010 | 1999 Oldsmobile Alero
Hoover wash-dryer 110 soft wave It doesn't centrifugate. I would imagine that I have to clean the filter, but I cannot find the filter. Thank you beforehand for your help. Christina
hi christina,,,its dont centrifugate???????? hmmm! do you mean spin?
or it dose spin,,, but dont pump out? if its not spining there is a program fault,,,or motor fault,,,,if it dont pump out,,,thats a pump fault,, program fault or a blocked filter,,,the pump has its own motor,,,however if there is a program fault that could cause the pump to fale to pump as well???
my brain hurts now!
Aug 07, 2010 | Hoover AAA160 Front Load Washer
Fuel pump runs and dont run at times wont start
First thing would be to either test or replace the relay which is under the hood. Do check the fuse as well. you can test power to the relay and also to the pump with a voltmeter. You can test the relay itself with an ohmmeter.
Jun 08, 2010 | 1988 Mercury Sable
Went to a store came back out would not start but strong battery,im tinking fuel pump dont know alot about car only had it a week
stand outside your van,reach in the window and turn your key over,but not to the start position. you should hear a whirring sound from the rear of the van and it should last about 2-3 sec. this will be your fuel pump powering up. if you dont hear it,then you have a bad fuel pump. Dodge Caravans from 96-01 are VERY bad about eating fuel pumps. if the pump is fine,have someone try to start it while you look under hood and see if injectors are spraying fuel. if the pump is good,and you have no spray from the injector,then you have a clogged fuel filter which will need replaced.
May 01, 2010 | 1999 Dodge Caravan
1986 BMW 318i;Turns over but engine wont run.I'm
Fuel pump may be getting weak. If pressure is not high enough the injectors wont open.
Jun 27, 2009 | 1986 BMW 3 Series
I dont have any power going to fuel pump what should i check
The power goes to pump when cranking with starter motor, look for the F/ pump RELAY or fuses, follow wire from back to front by color
Jan 22, 2009 | 1987 Ford Ranger
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
149 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
