Question about Toro Garden
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
  • ilepstein Aug 21, 2010
    ihave gotten the rear portion of the bellt backon .you see the belt was already off when i started so , how do we get the front portion of the belt on undwe the motor
    Genius:
  • 1,035 Answers
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Posted on Aug 19, 2010
  • 503 Answers
remove the battery and tray for access. Also remove shifter cover for access to the tension pulley to remove the small drive belt, from there releave tension and take off small drive belt, from there you should be able to turn belt and pull up on your long drive belt to remove it.
And you can get the Manual for it via
http://lawnandgarden.manualsonline.com/manuals/mfg/toro/14aq81rp74414ak81rk744.html
Please post your feedback and Vote if the problem resolved as per your satisfaction.
How do I replace a drive belt on a toro ride on mower model CV18S
+check with dealer, the service manager may help cheers.
Jan 12, 2015 | Toro Garden
How to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
Sep 15, 2012 | Toro Lawn Mower With Toro Power Tools
Replacing drive belt on toro 20017
Section 3 of this manual has the belt service instructions.
Jul 21, 2012 | Toro Power Lawn Mower
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro 521 snowblower instruction to replace belts
Remove bottom cover(4bolts) 3/8"Remove plastic housing cover (mine had 2 bolts)3/8"Loosen belt guide bolt.1/2" rotate guide away from belt.I used a pipe wrench to hold main shaft and removed drive pulley.Replace drive belt as you return pulley onto shaft.Replace auger belt.Align belt guidesSet handle adjustmentsReplace coversTest and hope for warm weather, I live in BuffaloHope this helps
Jan 01, 2011 | Washing Machines
I have a toro lawn mower. Model no. 20352. The drive belt came off the pulley. How do I reinstall?
Go to this URL:
https://icontent.toro.com/smartmanuals/22Recycler/Proc10806.htm
On the left side of the page there are a few items for maintaining your mower. One shows how to change the drive belt for a front drive and one shows for the rear drive. Click on the one you have and it will show you how to accomplish this task. Be sure to either tighten the belt so it does not fall off again, or if it is bad, replace the belt. Please follow all safety instructions.
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,781 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
