Question about GE Washing Machines
My GE washing machine has a slight leak coming from under the unit. I'm pretty handy so if its something simple I'd like to check it out myself before spending $$$ on a service call.
  • 712 Answers
Please check if the water outlet pipe is having some leaks or so and if yes, please try to replace it.
Posted on Aug 19, 2010
Whirlpool Quiet wash super capacity. MY washing machine is leaking from the bottom when it is in rinse cycle only.
Sounds like the pump, seal for pump or a hose. Pumps crack and leak sometimes. These are pretty easy to fix if you have basic tools and are pretty handy. Try to look under as it's leaking to find out exactly where the leak is coming from, then replace that part. Hope this helps. :)
Dec 24, 2010 | Washing Machines
Tip
Great instructions! I consider myself pretty handy and using these instructions...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I just bought a pretty old, used GE fridge. (It's a freezer on top model.) The fridge is cold but the freezer isn't cold enough. It just barely makes ice part of the time. Ice cream defrosts and bread...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 24, 2010 | GE Refrigerators
WATER LEAKING FROM UNDER THE WASHING MACHINE
follow the hose from where it connects into the washer.. take off that panel and pinpoint leak. more than likely a hose is unattached
Apr 15, 2009 | GE WWSE5200B Top Load Washer
Water from GE Washing Machine is coming from under my washer onto the floor
I would be happy to help you through this. The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with meatal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement. I just paid $59.99 for mine. It took me less than 30 minutes total to replace. Feel free to ask more questions. I love this kinda stuff. Good luck and let me know how it goes.
Tim....Denver, CO slamarama@comcast.net
Dec 12, 2008 | GE WBSR3140DW Top Load Washer
Washing machine leaking
They are not any more prone to leak than any other brand of front loader. He needs to take the bottom cover off and look for the source with a flashlight while the machine runs through a cycle. It could be something simple like a drain or fill hose or something much more difficult like the tub gasket. He will know that it is a tub gasket the leak originates where the two sections of the drum are fastened together.
Sep 15, 2008 | Frigidaire ATF6000ES Front Load Washer
I have a washing machine that is about 2 1/2 years old when i started a load of wash last night water started leaking out from under it. checked the hoses and there doesnt appear to be a leak in them. any...
Depends how handy and ambitious you want to be. :) Easiest thing to do is run another load with a flashlight handy. When you start to see water try to find where it is coming from. Make sure you are not overloading the machine with soap.
Apr 28, 2008 | Washing Machines
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Kenmore 110-91564100 Top Load Washer Problem
Sounds like my 91 Geo Merto LOL! Anywho when it washes the pump spins one way and water is basically thrown back into the tub, then when on spin it spins in the opposite direction and if there is a hose leak past the pump or the pump itself leaks it will come out of the drain system. As for the thump, check under the unit for anything that shouldnt be under there getting caught up in the mechanics. Let us know :-)
Sep 14, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
