Question about HP Office Equipment & Supplies
I am unable to print anything. First the printer makes an awful noise and it takes an awful time to trying to start printing, but nothing happens and the cancel light comes on. It also mentions OxcO5dO281. I hope you can help because we are very behind because of it. The ink cartridges are OK. Ankie Zeilstra.
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release in sequence the "1", "2" and "3" buttons.
Customer Name: ok
Customer Name: screen says "support" R0631M
2. Press and release the right arrow button until the display says "System Configuration Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photo Smart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
HP: Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Posted on Dec 21, 2010
Pump motor stalls in my HP printer
When an inkjet printer is making "awful noises" it means that there is either a paper jam or the carriage can't move properly. Remove all paper and check for a paper jam - if this is not the problem, turn off the printer and see if you can move the print cartridge carrier by hand. If it is hard to move, clean the shiny carriage rod with a cloth and put just a drop of light oil on it. Move the carriage back and forth and clean it again - repeat until it moves easily and add a final drop of oil to the rod.
Oct 14, 2014 | HP Photosmart C7280 All-in-One Printer
My lexmark t652 is making a squealing noise when printing
Try with another cartridge first.
Printer may have gears with broken teeth.
Oiling will not help.
Nov 22, 2013 | Computers & Internet
H p deskjet 3051a
Hi
Check through the paper path for any obstructions and manually remove them.
Check the cartridges and make sure nothing's trapped here [stuck papers].
Ensure there's no dry or damaged cartridges
Clear any print queues.
Disconnect the printer from power and from the PC.
Connect again after a while.
Try printing now.
Feb 29, 2012 | HP Office Equipment & Supplies
HP Photosmart C6280 All-in-One making weird noises
this is hope, i had this problem once. what it was was a small piece of paper that was caught in the rollers. i know you said this, but check again, I am almost positive this is your problem
lastly, check the black cartridge, take it out make sure nothing is stuck to the ink dispensary for clear printing
hope this helps and good luck
Apr 29, 2010 | Office Equipment & Supplies
When I try to cancel a print job it does nothing.
try to reinstall your printer after uninstalling the prior one.And also check your pc for any virus
Jul 10, 2009 | Office Equipment & Supplies
Printer won't print, makes clicking noise, on/off light flashing
This method should put you on a fresh footing.
1. Go to start button when programs appears see if you can find your printer in the list, see if it has an uninstall program.
2. If not: Go to start click on printers and faxes.
3. Delete the printer giving you a tough time.
4. Reinstall using your installation CD.
That should work.
Victor
Dec 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Why won't any documents print on Mac OS 10.5.2?
did you run a test page?
try the head alignment first
or the drivers are unhappy
http://tinyurl.com/6qcpgy
Jun 01, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
I keep getting the message unable to print see trouble shooting in manual
If trying to Print in Word 2003 - 2002 - 2002
Click on tools > options > Print tab > Uncheck Back Ground Printing. Click on ok. Try Printing.
If you are trying to Print from Word 2007.
Click on Office button > Word options > Advanced > Locate Print options and uncheck Backgound Printing click on ok. try Printing
Oct 19, 2007 | Brother MFC 210C All-In-One InkJet Printer
123 people viewed this question
Ben Johnson
