Question about HP OfficeJet 6110 All-In-One InkJet Printer
Screen on printer says: 1 copy / 100% How do you remove this?
  • tomkllc Aug 19, 2010
    Does anyone have the answer to this question?
    Guru:
  • 731 Answers
Partial reset can fix this problem
  • While the printer is ON, removed the power cable from back.
  • Press and hold # and 3 at the same time.
  • While holding # and 3, plug in the power cable and keep holding them for 10 seconds.
  • Release the button and check the display.
Regards,
Riztech
Posted on Aug 19, 2010
    Tried it---didn't work. Should I throw out the printer and buy a new one or can this problem be repaired. I can't enter a fax number to send a fax with: 1 copy / 100%
How do I copy smart label printer files from desktop to laptop
I'm making the assumption that your SmartLabel printer was installed on your desktop computer and now you want to use the SmartLabel printer on your laptop. I'm also assuming your what the addresses from your desktop computer. That said...
Seiko has eliminated the software and driver support for all older models but you can download the needed software from a third party site. Here's a link to the very stable version 4.61
Seiko SLP 100 Free Driver Download
Make SURE your SmartLabel Printer is NOT Connected!
Set Up Steps
A. Install SmartLAbel Printer on your laptop
1) Copy the Seiko software onto your laptop and begin the installation program.
2) At the point were the installation program asks, connect your SmartLabel printer
3) If the SmartLabel program is open, close it
B. Retrieve your SmartLabel addresses from your desktop
1) Look for the SmartLabel directory under Program Files on your desktop computer
2) in this directory find a file named label.sll This file holds your SmartLabel 100 addresses.
3) Copy the file to a USB Stick
C. Transfer your labels to your new installation on your laptop
1) After installing your new SmartLabel printer on your laptop. Insert the USB Stick in your laptop
2) Copy the label.sll file into the new SmartLabel directory under Program Files.
3) Start the SmartLabel software and open a new label, you should see the addresses from your desktop computer
4) If you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Hope this helps
Sep 28, 2014 | Seiko Smart Label Printer 100 Thermal
How do I enlarge copies on my photosmart C6180 printer
To Enlarge or Reduce.
1. Press Copy Menu
2. Select Size
3. Select Custom 100%- Hit O.K.
4. Custom percentage shows up
5. Use the Up Down function to enlarge or reduce
6. Hit Preview Button
7. If O.K. Press Start Copy for B/W or Colour
Feb 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
How to have multi inserts with 100 page book and make the copy come out like the book?
If your printer equiped with ADF( Automatic Document Feeder ) then use it. Just remove staple wires in the middle of the book and put it in ADF and start copying
Jan 06, 2011 | Office Equipment & Supplies
I have an hp psc 2110. I made some enlarged
Some basic steps to begin with:
1. Disconnect the printer from the computer and power off then back on. In some cases the problem can be caused by the print spooler on the computer.
2. If the problem persists, power off the printer and remove the power adapter. Leave the printer sit for 10 minutes or so, allowing the internal memory to clear, After which you should hook the printer back up and reconnect to the computer.
Finally determine if the printer is being recognized, on vista or windows 7 you can do this by clicking 'start' >> 'devices and printers'... or on xp 'start' >> 'control panel' >> 'printers and faxes'
If it is not listed as connected on the list (ie. offline) try uninstalling the printer and rerunning the drivers.
//halfs
May 25, 2010 | HP PSC 2110 All-In-One InkJet Printer
Hp Photosmart C4100 series (copy 6) printer missing!
Uninstall all those printers first. restart the computer and reinstall the drivers again.
May 25, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer won't work
Unplug the printer from the power and replug it in, the printer will go through its post(the little dance they do when they start up) and should come back to a ready status.
Gremlin11
Dec 13, 2008 | HP PSC 2175 All-In-One InkJet Printer
Completely frozen
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET printer reset
4)OK
Sep 13, 2008 | Canon PIXMA MP130 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
