Question about Euro-Pro Shark Professional Upright Vacuum with Bonus StickVac Red Bagless Vacuum
Brush rolls of my Euro-Pro Shark vacuum (model-UV 210CN) are stuck; the brush is unable to roll. Does that mean I have to the roll on one end or the whole brush unit? I live in Canada and if possible let me know where I can find a store. Thank you.
5 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: Bissell Vacuum brush stopped rolling
The belt may be broken. Consult the user manual or locate on the sole plate or front hood when getting to the sole plate. Usually it involves a few cross head screws on the base of the vacuum cleaner where the roller beater bar is. Remove that and check the belt. If its broken, carefully replace it with a new one and see if that works once everything else has been put back.
Posted on Mar 27, 2009
tomsat69
  • 219 Answers
SOURCE: Agitator brush roll needs replacement
To change the beater bar you would need to open up from the bottom.To get the parts you would need to produce the model and serial numbers to your local hoover dealeror cheak on the internet for your closet dealer and order the part.There not to bad to change hope i helped:)
Posted on May 18, 2009
dodge_is
  • 42 Answers
SOURCE: Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Posted on Feb 23, 2010
SOURCE: brush roll belt stops turning when in position to
VacuumRepair, can you describe what you think the nature of the problem might be without going to all the trouble immediately of photographing the repair? My Eureka 4870 has similar symptoms to those described. The brush stops very easily even at the highest height adjustment when it comes into contact with the carpet. I replaced the belt hoping that would help, but it doesn't seem to have done so. The brush control lever does seem to work correctly, and the motor seems to work well: lots of suction, and the motor shaft seems to rotate at high velocity. I still wonder if the belt's slipping too easily, and if the idler pulley isn't pressing firmly enough on the belt. Honestly, my wife's so frustrated with the brush stopping on this vacuum (and has never been happy with its edge cleaning) that we're looking to buy a new one.
Posted on Apr 19, 2010
Why does the brush roll stop rolling.?
You did not post the make and model. Most of the rollers are belt driven and the belt gets stretched or burned
Oct 10, 2017 | Vacuums
Why wont the roller brush turn on my navigator shark NV22L
It could be a bad switch or brush roll motor, a broken belt, loose wire or contact. You must inspect and test all these areas to narrow down the cause.
Feb 28, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
My shark vacuum is having problem 1st the hepa filter kept popping off I made that stop and now the brush won't turn what do I do
Usually a filter popping out means it needs cleaned or replaced. If the brush won't turn it may be the belt, or depending on your model it could be the brush roll or brushroll motor, switch, wiring etc. check these items.
Jan 12, 2017 | Shark Vacuums
Shark rotator nv340 roller brush is not spinning
just found this from another fixya member....There are a number of reasons why your brush roll has stopped spinning on your Shark Rotator. Here are a few things to check for when trying to fix your Shark.
First things first lets focus on the brush roll. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roll. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roll to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roll is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. This could be the other reason why your brush roll has stopped spinning. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush rolls turn rate and speed. If the belt feels loose then it certainly is effecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Dec 09, 2016 | Shark Vacuums
Brush rolling but the machine will not roll on the carpet
check to see if there is a button to push to lift the front part of your vacume up maybe to close to the carpet or your back wheels have something stuck in them
Jul 13, 2016 | Shark Navigator Bagless Upright Vacuum
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
Why does my brush turn?
Most likely the belt that connects the motor to the brush has broken and needs to be replaced. A relatively easy fix.
Nov 12, 2014 | Shark 12-Volt Cordless Hand Vac
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Feb 06, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Brush roller won.t turn. It turns for a sec. then shuts off. I have cleaned all clogs. This is a shark navigator. Can I remove bottom of vac to access the roller? The manual doesn,t mention this as a...
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance of your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they lose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 06, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Shark Euro Pro upright vacuum V1310RS
Most vacuums you either remove the bottom plate, or the top cover comes off. If no screws on the top cover, then turn vac. over and remove the screws on the bottom. Then you should be able to get to the brush roll and belt.
Feb 15, 2008 | Vacuums
Euro-Pro Shark Professional Upright Vacuum with Bonus StickVac Red Bagless Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
