Question about Dometic Rooftop RV Air Conditioner
Just Installed a Dometic Rooftop air conditioner I Have 2 supply ducts that feed each end of the home the supply duct are not putting out any air when I took the cover off the unit seems to be blowing out a sufficient amount of air but am wondering how the air is suppose to get into the ducts
    Master:
    Sergeant:
  • 449 Answers
Usually in moble homes the air flow has terrable air restiction in most cases this is compansated with higher volumes of air flow (your gong to have to increase the blower fan speed to compensate. hope this helps
Posted on Aug 19, 2010
Why will my Dometic air conditioner only cool to 15 degrees below ambient temperature?
A few things can determine that , or cause it. First of all, where are you checking the ambient air temperature and what type of system do you have, is it ducted, blows out of ceiling assy? Has unit been properly cleaned lately? If ducted, have you checked for cool air leaking by to return air box?
Aug 15, 2014 | Dometic Rooftop RV Air Conditioner
Own 2005 27.5' Wildwood Trailer with a Dometic a/c ducted unit. Last few times out it freezes up initially first few times (pocked circuit breaker once then I turned it off after few minutes second time)....
Don't block off any ceiling ducts and see what happens. If you've closed off any forced air ducts, the unit will freeze up, if too many are closed off. Also, if you shut unit off (compressor) give it 5 or 10 minutes before you turn it back on.
May 21, 2010 | Dometic Rooftop RV Air Conditioner
TRYING TO FIND THE RIGHT DUCTED AIRCONDITIONER COLMAN. FOR 1995 TRAILER
The upper unit doesn't matter ( the actual ac unit on roof ) it's the lower control unit (inside at ceiling) that you need to change to use either ducted or non-ducted system. Any RV dealer can supply that, probably have it on the shelf. Just make sure you write down the model number and serial number, off the bottom of the upper unit, so they can match lower unit to it, for ducted system.
Apr 14, 2010 | Dometic Rooftop RV Air Conditioner
What is the difference between ducted roof air and non ducted.
Non-ducted units blow the cooled air out louvers on the unit. Ducted units discharge into a duct system like your home furnace. (Or RV Furnace (heater)).
Apr 10, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop air conditioner 8000 model. When on heat in cold climate I found the a/c unit did not heat our caravan sufficiently.
the reason for this is either the reverser valve or air restriction first clean the a/c by removeing the cover on the roof and the inside clean the cooling fins then remove the sheet metal or plastic cover over the intake fan & clean the shroud then clean the filters inside the van reassemble every thing then turn the unit on & from inside check the side were the wires are to feel for air by turning the unit on cool there should be a big diffrance between the intake from the out put use duct tape to seal off the sides also clean the duct work with air to remove blockage in the duct
Jun 05, 2009 | Dometic Rooftop RV Air Conditioner
I have a dometic duo-therm. No air coming through ducts.
Sounds like the ducting have come apart in some areas or blocked in some way. Take the supply grills off and with a shop vacuum try and reach as far as you can.
Mar 18, 2009 | Dometic Rooftop RV Air Conditioner
Ammonia smell when Dometic Air Comditioner is on
sounds like you have an old unit and it has a leak , the real old units where filled with ammonia as the gas
Feb 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic rooftop air conditioner coil freezeup
We did find a solution, the ducts leading to bedroom in RV was blocked. So far, it has been working since we cleared the way, it no longer freezes up. Thank you.
Nov 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
106 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
