THE MICROPHONE IS HOOKED UP PROPERLY AND HAS BEEN TESTED BUT I CAN'T HEAR ANYTHING ONCE I LEAVE MY CONTROL PANEL SETTINGS
Http://crystal-iced.com
Posted on Jul 20, 2008
Desk microphone
Is the microphone phantom powered, with a battery or dynamic?
Nov 05, 2013 | Dell LATITUDE Computers & Internet
Microphone not working settings
you must sure if the microphone is working, will be a great idea that if you can test in another computer, in that way you see if it is the computer or microphone.
However you must try to restore go to control panel, use the utility system restore, and put the last date that you know was working Good.
Or open the sound in control panel and RUN the troubleshooting in tab for microphone.
God bless you
Jul 18, 2013 | Dell Inspiron N5030 Notebook
When people skype they cannot hear me
Step 1:
Click start control panel sounds and audio devices audio and also voice its the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume Make sure the box for microphone has a tick in it
Feb 08, 2013 | Computers & Internet
I can not use my internal microphone with Skype
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice its the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope it helps
Oct 04, 2012 | Dell Latitude E6400 Laptop
I cant hear my friend in skype
click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
hope it helps
Oct 03, 2012 | Logitech Audio Players & Recorders
My built in mic is not working properly,when I call somebody hear me but I don't hear him!
If the other person can hear you then YOUR microphone is working fine.
The reason may be that his microphone is faulty (solution below)
Otherwise:
  1. Make sure the volume is turned up on your speakers (and if using external speakers they are plugged in / turned on) . To increase volume go to Control Panel, Sounds & Audio Devices and adjust the slider on "Device Volume" . Also click on "Loudspeaker Volume" and adjust the sliders there as necessary.
  2. Can you hear other sounds (like playing music or videos)? If yes then you need to adjust the audio settings for your calling program (skype or whatever). Launch the appropriate program Click on Tools and ' test audio properties' on the program tool-bar. Follow the instructions on the screen.
  3. Try plugging in headphones and see if you can hear better on them.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 09, 2011 | Toshiba (P000257700) Microphone
It doest record anything and also i cant talk on skype i could hear whoever i am talking to but they cant hear me
First test your microphone to see if it is working properly. Click on Start All Programs - Accessories - Entertainment - Sound recorder and record your voice and play it back.
If it does not work, then reinstall the microphone driver and test again. When the microphone works then open Skype and configure the Audio settings.
For details on configuring the microphone in Skype, click on this link and follow my instructions :-
http://www.fixya.com/support/r6522317-skype_microphone_problem
Jan 04, 2011 | Computers & Internet
Since I had to have windows XP home version re-installed to fix a problem, I have been unable to use my headset and microphone to use Skype. My settings all confirm I am supposed to be using my Realtek HD...
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or
Dec 14, 2010 | Computers & Internet
Hi. i am a regular user of google talk..but since one week i cant talk properly thru google talk.i caould hear from the other end..but they can hear only my broken voice.my head phones work fine with...
Make sure the volume for your microphone is turned on. Here's how:
  1. Click the 'Start' menu in your taskbar, and highlight 'Settings.'
  2. Select 'Control Panel.'
  3. Locate 'Sounds and Audio Devices' in the Control Panel, and double-click the icon.
  4. Open the 'Volume' tab, and click 'Advanced...' in the 'Device volume' section.
  5. Look for 'Microphone' in the 'Volume Control' box that opens, and make sure your microphone is enabled and the volume is high enough.
  6. Close the 'Volume Control' box, and then click 'OK.'
If you're using an external microphone, and the volume is set properly, check that the device is securely connected to your computer.
And if that doesn't solve the problem, make sure your microphone of choice is selected in the 'Output - speakers or headset' drop-down menu in the 'Audio' section of your Google Talk Settings.
Cheers!!
Oct 18, 2010 | Google Talk
Hello, i cant hear the microphone over the speaker
Make sure your microphone is not muted in the control panel, under sounds.
Nov 20, 2009 | Gateway Computers & Internet
21 people viewed this question
 Grubhead
Grubhead
