Question about GE Dryers
General electric heavy duty automatic dryer won't start after running heavy load
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 19, 2010
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Admiral heavy duty super capacity 5 cycle3 temperature won't start
dryer will not start when start button id pushed
Aug 07, 2012 | Admiral Dryers
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
I have a General Electric Clothes Dryer that will now turn on when I hit the start button. It is wired to a 220 circuit and is getting power to the machine. Model number DDE804SLKCWH Heavy Duty 18. Im...
There could be a number of things that would do that...As this tip will show you, the thermal fuse is the first place to start...
There is also a list of other things to check here also...
heatman101
Apr 07, 2010 | Dryers
I have a Roper electric dryer 5 cycle heavy duty XL capacity model #REX5635EQ2 & it just won't start, any suggestions? I have not had any problems with this dryer before & empty the dryer vent...
It has a bad thermal fuse located on the blower housing . A narrow white piece with 2 wires attached to it . Unplug dryer before replacing .
Jul 19, 2009 | Dryers
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
Kenmore Heavy Duty Dryer
If the dryer is still powered on but the motor stops, it sounds like the over load in the motor is cutting out and the motor will have to be replaced.
Feb 23, 2009 | Kenmore 63942 Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
235 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
