Will not mute or volume work off the tv remote
  • 17,129 Answers
The remote control unit is faulty for sure. Since the mostt used buttons are the volume control pads it is possible that the carbon under the pads are worn out or the track on the remote control boarrd is faulty.
If you can get the carbon pen, the draw the track on the board and stick the carbon dots( spare available) on the pads .
If this wont work solder IC.as the last resort.
Hope this helps. Good day
Posted on Aug 19, 2010
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Volume/mute do not work
You have to program the remote to your specific TV.
Feb 04, 2014 | AT&T UVerse
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
Mute is on won't shut off.
Tries pushes the volume button up on the remote or the tv volume manual button + - the mute,will go away,the mute button on the remote don't work?The tv remote crontrol is dying.
Feb 03, 2011 | Panasonic Televison & Video
How to enter service mode 43h83 toshiba mute 3 times mute again and hold menu on tv dont work also volume alway down on tv press hold 9 no go also help need to adj convergence
Its press mute on the remote twice. Then for the third time on the remote press the mute on the remote and while pressing the mute that third time press menu on the front of the TV
Nov 28, 2009 | Televison & Video
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
