Question about Sunbeam 4039 Iron
Our sunbeam iron got hot scorched the cloth and then stopped heating up. There was a smell of something burning, but a precursory search showed no burning.
  • Sunbeam Master
  • 43,501 Answers
Here is a tio that will help you ....
many times the problem is in the thermostat..
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Aug 19, 2010
Sunbeam iron 5900 2400 watt not become hot. Now what can I do?
opps sr 5900 2400 watt have mixed consumer confidence
http://www.productreview.com.au/p/sunbeam-ultura-sr5900.html
if the dial or iron wont heat up at all
most sunbeam irons have 12 month warranty
if less than 12 months old and you have the reciept
take it back for refund or exchange
if out of warranty toss in the bin...... buy a new iron
Sep 20, 2016 | Sunbeam Irons
Off and on blinking red and green will not stay on cotton level
I feel it is trying to tell you something ,something like I'm too hot and I don't want to burn up-yes I'd say that probably trying to say-cheers Denny
Oct 11, 2013 | Sunbeam Irons
Bosch iron TDA8320/01 soleplate marked
pan scrub or brillo pad soft wire wool you could heat the iron up and use hot soapy water on a dishcloth but be careful not to burn fingers as the cloth will get hot aswell
Apr 01, 2013 | Bosch TDA8340 Iron
Does not heat up
Visual Check:
1. Do you smell burned electrical wire? If none,
2. Check the cord for damage, and the outlet for electricity ((plug in another device and see if it turns on)). If none,
3. Does the water reservoir or iron face have visible mineral deposits (i.e. need cleaning)?
Possible solutions:
1. On COLD, UNPLUGGED iron, clean working surface with non-abrasive cloth.
2. Try Vinegar & Water cleaning to remove mineral deposits (if warranty allows):
Mix equal parts water and white vinegar (abt. 1/3 cup each).
Pour into water reservoir.
Turn on the iron with steam option.
Allow to work, upright, for 2-3 minutes.
Turn all controls to low before unplugging.
Drain into sink ...carefully, it may be hot!
Flush with plain water.
Reheat iron and test on scrap cloth to clear any residue.
BE SAFE and work carefully. If iron still does not heat after thorough inspection and cleaning, the unit may need a qualified technician.
Dec 29, 2012 | Bosch Irons
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
Iron worked fine yesterday today it turns on but does not heat up Any answers? Is it shot?
Simply, something internally failed. Probably burned out a component, it happens. So yes, it is shot and it's time to invest in a new iron. Let me know if I can help you with anything else.
Benjamin
Nov 04, 2010 | Sunbeam 4243 Iron
4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Aug 04, 2009 | Sunbeam Irons
How do i clean the plate of the bernina pro glide iron, it sticks when i am ironing.   my mistake, called Bernette ProGlide Plus  Model #1660 (an older iron, was my mothers, but still works)...
I have used the cleaner that is used for the corning cook tops (smooth cook top range cleaners).. It has worked great on mine...Hope this helps.
May 18, 2009 | Irons
Sunbeam 4039 Iron Logo
151 people viewed this question
Top Sunbeam Irons Experts
Henry  Thomas
Henry Thomas
Tony
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
