Question about Garmin nuvi 200W GPS Receiver
Voice dosen't work - Garmin nuvi 200W GPS Receiver
    President:
  • 1,514 Answers
1. Press the Volume (Speaker symbol) in the bottom right corner and check that the mute box is not ticked. If it is press it and it will be ok. Also check that the volume isn't fully down.
If that doesn't solve the problem it may be because the voice file is not selected or has become corrupted.
2. Press Tools, then press Settings, then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
3. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 2 above.
Posted on Aug 20, 2010
The sound from the left output device dosen't work
I would also first switch left and right to check the cables
Feb 20, 2013 | Simmons SD7PK Electronic Drum Set
1999 grand am speedo dosen't work. put a new senser in still dosen't work
Sounds like you have some electrical corrosion in a connection somewhere in that system causing the low voltage. Take the connectors apart and clean them and that should help
Jan 07, 2013 | 1999 Pontiac Grand Am GT
Webcam companion4 dosen`t work, side-by-side configration uncorrect
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 29, 2012 | Sony Vaio Vpceh25fm/b Core Pc I3 Laptop
Heater dosen,t work
you might have a problem with your heater core ,also check your radiator and make sure it is full if you are low on water that will also cause cold air to blow or your actuator witch is a control switch that opens the vale to let hot water pass through giving you hot air good luck
Nov 30, 2011 | 1997 Chevrolet Lumina
My Samsung BDC6900XXA 3D BLUE RAY PLAYER DOSEN'T WORK, IT WAS WORKING GREAT THEN MY INTERNET WAS INTERRUPTED FOR 1 DAY THEN THE INTERNET WAS CONNECTED AND NOW THE BLUE RAY PLAYER TURNS ON BUT...
I have seen this happen before when an update went bad right in the middle of an Internet outage. If you bought this recently, try to return it for a replacement. Otherwise, you will have to contact Samsung's support line to see if there is a Factory hard reset.
Aug 25, 2011 | Samsung BDC6900 3D Bluray Disc Player
Mail
"Doesn't work" is too vague a symptom to hazard any analysis.
Yes, you can send from Yahoo Mail to Apple Mail. But I'm sure that answer doesn't actually help you in the least.
I suggest you have a voice chat with someone who can help you configure Apple Mail properly.
Oct 15, 2008 | Computers & Internet
Garmin nuvi 200W GPS Receiver Logo
55 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
