Question about Kenmore 63942 Dryer
How do I replace the heating element for the Kenmore series 90 dryer?
Please advise
  • 1 more comment
  • mario7 Dec 07, 2008
    where do i find it at..?
  • asotolp Dec 11, 2008
    Dryer will not heat up at all. blows cold air
  • Mike Durland
    Mike Durland May 11, 2010
    need more info.
Replace heating element on kenmore dryer 90 series
Posted on Mar 05, 2010
  • 481 Answers
Let me know if you need  help
Posted on Jul 04, 2008
5 Suggested Answers
  • 5 Answers
SOURCE: heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: no heat
check the vent to the outside for an odstruction of lint
Posted on Dec 07, 2008
  • 1218 Answers
SOURCE: kenmore 90 series elec dryer,replaced heating
Several things to check. Be sure you have the correct voltage to the unit.
Since this is an electrical heated device, it is loaded with safety switches. There is sometimes a thermal overload,or clix-on bimetal device in the exhaust inside the rear of the unit. If your exhaust becomes restricted, it will take the heater out of the circuit. If you do not have enough air flow, the element would burn up/ out. I would look around again as I'm sure there are other safety devices as the one I mentioned as well as one near the element to prevent overheating.
The timer is also responsible for sending power to the element as well as the motor.
Good Luck and hope this helps.
Posted on Mar 10, 2009
protek480
  • 1714 Answers
SOURCE: My Kenmore 90 series dryer runs but will not heat
watch the video:
Posted on Jul 11, 2009
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Replaced heating element/worked for 10 min now doesnt
Howdy: Check the thermostat on the inside in the back. If unpluged or lint is clinging to it , the unit will shut off heat. Please inspect. Good luck - It also could be defective. - Doug
Dec 09, 2009 | Kenmore Dryers
Where do I find the heating element in a Kenmore 70 series dryer model 110.96575100
the part number you will need is 279838 and you can get that at whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Dryers
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
Dryer heating element for Sears 90 series model
there is a screw on the left side of the box where you unplugged the eelement that has to be removed,it goes in and out very tight,make sure you don't break any of the coils,this is the dryer that the front bottom panel comes off right?mike
Mar 17, 2009 | Kenmore 62602 Electric Dryer
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
No heat
Dec 07, 2008 | Kenmore Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
982 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
