Question about Lands Phones
AT&T cut my phone line by mistake; phone off for a week. People left messages because recording still worked. Now that I have my phone back on, I can't get my messages because the phone will not accept my password and gives me no options - just cuts me off!
  • 1 more comment
  • bjsimecka Aug 22, 2010
    My local provider isn't going to be able to tell how to get my Uniden phone recorder fixed. I am asking for help from Uniden - how do I put in a new password and can I retrieve my messages?
    Thanks - Betty Simecka
  • bjsimecka Aug 26, 2010
    Didn't work - do you have a Uniden phone? Nothing works - menu, nothing! Just the stupid recorder telling me my password doesn't work.
  • bjsimecka Aug 29, 2010
    So far no one has helped with a solution....what did i pay for????
    President:
  • 563 Answers
Try to press 0 during the outgoing message and then your 4-digit pin.
Posted on Aug 22, 2010
  • 905 Answers
Since your telephone service was able to still record messages, your voicemail likely resides on the telco computers. They are the ones that are rejecting your password / PIN. It likely has been reset back to the default while the line was being repaired as part of troubleshooting. You will likely have to contact customer service or line repair departments again.
Posted on Aug 19, 2010
How do I change the message on my answering machine?
Which Uniden phone do you have? for some models, you access the Answering System menu from the base; on others, you need to be holding the handset. The generic steps are below.
On the appropriate part of the unit, make sure that the phone system is in standby (no active calls on any handset). Then press Menu. Use the arrow keys to find the line for Answering System. Press OK. Navigate to a line about Greeting and press OK. You should see (and select a line) for Recording message. You'll be prompted to ensure that you want to record a new message. If you are using the handset, hold the unit about 6" away from your head. After confirming that you wish to record a new message, speak your new message clearly. When you are done, press End. The unit will cut off the recording if your message was too long. Make sure to save the message. Then go back up in the Menu system and look for a line for "Play back Greeting". If the message isn't clear, start over.
I hope this helps. Please add a comment with the model number of the phone for specifics for your manual. Some DECT phone manuals are available here: http://www.uniden.com.au/australia/cs_operating_manuals_phones.asp .
Nov 21, 2015 | Uniden DECT 6.0 Cordless Phone
Can the digital recording be cleaned; I get lots of static on a recorded message?
There's nothing in your recorder to clean, but. . Static in the message likely indicates a problem with the phone line itself, or at least the connection from the phone line to the recorder. You can clean that.
May 26, 2015 | Lands Phones
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Will my answering machine work with my u-verse
Unfortunately it may or may not be fully compatible. First you will need to make sure that all call forwarding features are turned off for your voice service so that calls will not go to voice mail before your machine can pick up. Now is where the issue of compatibility comes in, most answering machines continue recording messages until a certain amount of silence is detected on the line and the recording then stops. With some machines the period of time before the recording stops is too long, when the other party hangs up the phone the systems puts out a busy dial tone signal which the machine may mistake as a continuous message and use up all the space for messages on a single call. This of course means no other messages can be recorded till the previous message has been deleted. So to see if your machine is fully compatible means you must simply try and see.
Feb 18, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
RCA 25250 can I record a different message for each line of the 2
hi... ya u can record it..... no doubt in that...
thank u rate me
Feb 09, 2009 | RCA 25250RE1 2-Line Cordless Phone
Unable to record out-going message
I CAN NOT GET THE FRONT KNOB OFF OF MY DYNA GLO K-1 KEROSENE HEATER. DIRECTIONS SAY JUST PULL OFF, I HAVE PULLED AND PULLED IT'S NOT COMING.IT MUST BE SCREWED IN SOMEWHERE THAT I CAN'T SEE.
Jan 16, 2009 | RCA ViSYS 2-Line Speakerphone
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
Messages are cut off at the end
maybe you havea time limit that it can record for. or maybe it is onthe line you use and not the mahine.
Jul 15, 2008 | Lands Phones
Weekly timer recording not working
Have you tried setting the clock to manual mode: Page 18 in the manual I think.
Jun 30, 2007 | LG DBRH197H DVD Player/HDD Recorder
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
