Question about Panasonic PV-GS19 Mini DV Digital Camcorder
Little red box with red line through it is in the middle of my screen. And it want record or take pictures. Why want it work?
Check if there is a tape in the camcorder and check the record safe tab on the tape. (The little white or red tab on the bottom right of the tape.)
Posted on Nov 10, 2008
My tv is 2 years old and in the last month or so in the middle of a show the screen will go black and a red line runs down the middle and it lasts for about 5 min and a little pop sound and the picture...
It appears you may have had a line collapse caused by a poor connection in the line output stage, it would be a matter of resoldering around this area. Now that you say it will come on could indicate that a component has now failed as a result of the line collapsing, more than likely the line output transistor has now also failed & would need replacing.
Jul 01, 2009 | Jensen Q2749J 27" TV
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Rca 61130 rear projection tv has pink haze
Try adjusting your Red screen control down just a little. This is usually a sign of the red crt developing a short. Often just turning the Red drive down just a bit will make the retrace lines disappear if not you will eventually need a new CRT or repairs in the red drive circuitry. Hope this helps.
Jan 26, 2008 | Televison & Video
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Toshiba theatreview
sounds like vertical problem maybe bad solder connections on vertical ic check and get back to me
Nov 03, 2007 | Televison & Video
Panasonic PV-GS19 Mini DV Digital Camcorder Logo
87 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
