Question about Watches
I got water damage in my watch and need the quickest way to fix it please
  • 831 Answers
Step 1 - Minimize the Moisture If your watch is exposed to moisture or falls into water, the first thing you want to do is move it to a dry location. Dry off the water on the outside of the watch with a soft rag. The glass on the front can be easily scratched, so be sure to use a soft cloth to wipe clean.
Step 2 - Remove the Cover Open the cover on the back of the watch very carefully. Often a small flathead screwdriver will help in turning the cover. Pour any water out that remains. Be careful not to touch any of the gears or parts of the watch as the watch may become irreparable.
Step 3 - Air Dry Lay the watch face down in a warm room to allow it to air dry for at least 24 hours. After replacing the cover, the watch will often return to normal use. However, it is still recommended to have the watch repaired by a professional watch repair shop. They will be able to seal the front and back properly to assure no future leaks. Have them run a pressure test to ensure there are no potential leak areas.
Standard Upkeep Proper maintenance is imperative, especially on delicate mechanisms like timepieces. Even before your watch fills with moisture or stops working, it is a good idea to maintain it on a regular basis. The inside of a watch is filled with tiny gears and sensitive parts that must be installed perfectly to work properly. Under normal use and regular maintenance, a good watch will work for a lifetime.
It is important to minimize wear and tear when possible. Even though you may not see a crack in the seal, there very well may be one that could ruin your timepiece. Water, especially salt water, can be very damaging to a watch. Find a reputable repair shop to recommend a maintenance schedule for your timepiece.
Read more: http://www.doityourself.com/stry/how-to-repair-a-watch-with-water-damage#ixzz0x91faKz5 Step 1 - Minimize the Moisture If your watch is exposed to moisture or falls into water, the first thing you want to do is move it to a dry location. Dry off the water on the outside of the watch with a soft rag. The glass on the front can be easily scratched, so be sure to use a soft cloth to wipe clean.
Posted on Aug 19, 2010
I DROP MY WATCH CODE REF IS 1142 I BROKE THE GLASS WHERE CAN I BUY A REPLACEMENT GLASS FROM
Getting a glass shouldn't be a problem, but as it sounds as though you intend to fix it yourself, then please be aware of the following.
It is essential to get the correct size glass - even 0.5mm difference in the diameter means either it won't fit or it's too small and falls out again. As you say that the glass is broken, I would be surprised if you could remove it and still determine the correct diameter.
You need to think not only about how to remove the broken glass, but also about how you are going to fix the replacement one. Many watches have a very fine plastic ring around the glass that holds it in place and this may have also been damaged.
Also, with many watches it's necessary to remove the back, crown and movement to effectively replace the glass.
If your watch has any sort of water-resistance rating then it would need to be retested afterwards.
Bearing all this in mind, I strongly advise you to take your watch to a reputable watch repairer and let them sort it out.
If the glass is anything other than round, then the cost tends to go up. Get an estimate from them first, and decide if what they will charge you is reasonable - if it isn't then spend the money on a new watch.
Hope this is helpful.
Oct 22, 2017 | The Watches
My watch face has water droplets on the inside of the crystal face. what can I do?
I have a burberry watch and it has water droplets in it but its only the middle that's full of water dropplet
Oct 03, 2010 | Timex 27191 Wristwatch
I have water/condensation in the watch.
  • Decide whether the risk of possibly damaging the watch is worth attempting a do-it-yourself fix. If the watch is expensive, you may want to have a professional repair it rather than risk damaging the watch or invalidating the manufacturer's warranty.
  • Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
  • Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
  • Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
  • Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
  • Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
  • Hope this helps!!
    Aug 21, 2010 | TechnoMarine TMAXS07 Watch for Women
    I have a Seamaster Omega Watch since last week have a fogging insde the watch
  • Aug 15, 2010 | Watches
    I have condensation on the inside of the glass on my watch. I have a pr50 automatic so i don't know if the normal jeweler will be able to fix it. It doesn't have a battery and was recomneded to me to send...
  • Aug 14, 2010 | Watches
    Red rubber around watch faded
    My experience with Tag Heuer is that if it is covered under warranty, they will fix it. If not - they will fix it at significant cost. My stainless steel Tag was repaired after water damage for over $300.
    Alternatively, if the watch still works, sell it on eBay but be clear that it is sold as a used watch, and show a clear picture of the face of the watch so buyers can see the fading. Some buyers will not care. Use the money to buy a new watch.
    Nov 25, 2009 | Tag Heuer WAH1112.BT0714 Formula 1 watch
    Watch leaked and stopped working .. I soaked it in lceaning fluid as I have always done...what can I do..who can fix it..I sent it to Watchrepairusa.com cost m3 $40.00 to send..they now inform me after 2...
    For sure water is a killer of watches. It only takes a very small amount to cause corrosion and damage. Most high end watches like Rolex will not repair them, you just have to get a new movement.
    Oct 29, 2009 | Cartier Santos W20011C4 Wrist Watch
    Replace a battery cover in a guess watch
    Your watch case back (battery cover) actually lost it shape some how that's why it's not closing, it's need alignment,
    which take lots of time try expert watchmaker hope you get it fix.
    even thought it fix some time it's lost capability to keep your watch save from water.
    hope this info help
    From
    AmFix Jewelry & Watch Repair
    203 N. LaSalle Street
    Chicago, IL 60601
    Ph: 312 641 7000
    Email: info@goamfix.com
    Web: www.goamfix.com
    Oct 01, 2009 | Guess G85675G WristwWatch
    How to remove back to replace battery
    take it to a reputable jeweler who can water test after the cell is replaced...if the gasket gets damaged with the caseback off the watch it will no longer be water resistant and will most definately rust if exposed to water
    Apr 24, 2009 | Navy Seal Luminox Dive Watch
    Water damage to my watch
    try this :
    This works on most mini electronic devices like cellular phones and degital cameras etc .
    it sounds crazy .
    Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
    Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
    Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
    It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
    beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
    This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
    related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
    rate if useful please !
    Mar 18, 2008 | Citizen Ladies Strap Quartz Watch
    Watches Logo
    492 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
