Question about Neff Cooktops
Hi, I have a Neff T1571 ceramic cook top with a fault or two. Fistly, when the front Halogen hobs are set to Zero on the display, they will still suddenly burst into life. Only when switched off on the display, will this stop. At Zero setting, shouldn't they be off? Secondly, two of the hot-plates will only display the number settings 1-9 (they should go 1-12) and when switched on and turned up, they only go to 2. Only by using the minus keys will they go "down' to the higher numbers. Is there a reset for this? Many thanks!
SOURCE: Stoves 700CTH hob
Hi, this worked for me as well on a 900CTH. Has to be a design fault judging by the number of people with the same problem.
No idea what this capacitor does but a guess would be that it is the reset circuit for the processor. This is normally a simple CR circuit which holds the reset pin down so the processor resets on power up. Only in this case their design does not hold the pin down long enough hence increasing the capacitor from 220 to 1000 micro-farads increases the time constant so that the pin is held down long enough. The installed value probably works well initially but due to the heat on the hob the capacitor ages, capacitance decreases in value (a common issue with electrolytics) and low temperatures at start up exhibit lower capacitances hence the fault is, as reported, worse in cold conditions. So my additional advice would be to pick a replacement with a high temperature rating.
Posted on Apr 07, 2010
SOURCE: Safety lock on Neff hob
to deactivate mine is as follows (copied verbatim from the manual)
to deactivate the childproof lock is the reversal of setting it -
turn all four hotplates to setting 2
turn off all the hotplates in order from right to left
touch the main switch for at least 5 seconds, once the five seconds is up you will hear an accoustic noise.
it is now deactivated
to turn it on with the childproof lock on you have to touch the main switch for 4 seconds
Posted on Sep 29, 2008
  • 222 Answers
SOURCE: neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Posted on Jan 27, 2009
Kgt1962
  • 59 Answers
SOURCE: Neff T1722SO Ceramic Hob - rings don't heat
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Posted on Mar 11, 2009
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
May 28, 2009 | Neff 23 in. T4343 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Neff T1722 so 02 ceramic hob
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Cooktops Logo
122 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
