Question about LG DLE5977 Electric Dryer
Lg 7188 gas dryer conversion to lp
How do I get into the dryer to change the oriface to lp? We can't figure out how to get the front of the dryer off.
  • lfromhertz Apr 26, 2009
    I can't get the back off the dryer to get to the gas part.
I am not seeing the solution. Please help.
Posted on Apr 26, 2009
How do you get the front off a LG gas dryer
Posted on Jul 26, 2008
Disassembly of an LG DLGX2802L Dryer to replace gas oriface
The top must come off in order to work on orifice. remove the top and then remove the side nuts and it will slide forward after the top off.
Jun 19, 2009 | LG DLG5932W Gas Dryer
I HAVE THE GAS REGULATOR AND LINE OUT OF DRYER,DO I DISCONNECT THE GAS LINE AT REGULATOR AND INSTALL THE CONVERSION AT THAT POINT,LOOKS LIKE IT WILL REQUIRE ME TO ALSO INSTALL A NEW LINE TO BACK OF...
No, the conversion requires you to change the orifice and adjust the regulator to LP. The instructions should tell you how to do the conversion.
Good luck
Sep 24, 2010 | LG DLG9588 Dryer
Converting broiler in oven from natural gas to lp gas on hotpoint gas range
On the oven portion you will need to turn the oriface clockwise all the way till it bottoms out. This is the conversion from natural gas to lp gas on all gas ovens. Also make sure the valve down toward the back has been flipped off of nat. to lp. Good luck
Mar 02, 2010 | Hotpoint RGB745 Gas Kitchen Range
Natural gas to propane conversion LG dryer
You posted under a combo washer / dryer WD-4343RHD.
For a gas dryer, conversion is to replace Nat gas orifice with LP one (the LP orifice has a air hole going cross ways through it) plus screwing the regulator blocker (brass slot head screw on top of the gas valve) all the way down (if you missed that step, I would expect your symptoms). Also, make sure you have a good vent with strong air flow at the outdoor outlet. If poor vent, short cycling may occur.
Nov 22, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Remove front of Dryer
go to appliancejunk.com and you can download the service manual. also make sure you don't move the set nut on the change screw.when you turn it in it take a little muscle. stubby screwdrivers are a must. we also removed the tube(2 scews)that was in the way of the oriface.if i had to do it again i could do it again it would be a snap
Feb 01, 2008 | LG DLG2524 Gas Dryer
Lp conversion
You guys like things that go boom. My advice is to get a certified gas tech. To change the orfice to LP you have to take apart the unit from the front.
Sgt 48
Jan 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
LG 6988 gas dryer conversion
you will need to get to the gas valve right front after the panel is off the orfice is in the end if the burner
Jan 25, 2008 | LG DLE0332 Gas Dryer
Lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Nov 18, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Lg conversion to lp
remove the top, and than the control panel, and than the front will come off to expose the gas burner on the bottom right side...
Oct 25, 2007 | LG DLE5977 Electric Dryer
LG DLE5977 Electric Dryer Logo
193 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
