Question about Iomega 500GB eGo BlackBelt Portable 34621 500 GB Parallel Hard Drive
Hello, I need instructions on how to reformat my Iomega 500GB Blackbelt HD back to factory settings. I originally set it up to run on a MAC OSX system running Snow Leopard 10.4. The HD now needs to operate on Gateway computer running Windows Vista. I've been unsuccessful in reformatting on my own. Please help!!! Thank you!! CMC
5 Suggested Answers
crok41
  • 621 Answers
SOURCE: I have the Iomega model
Goto control panel / computer management / disk management now you should see all your drives right click your 160Mb drive and select delete partition. Now right click it again and select format, choose the Fat32 file system and give it a full format not a quick one seeming its been used on a Mac and you shouldnt have a problem. Cheers from Scott and plz vote
Posted on Jan 25, 2011
nonontech
  • 4737 Answers
SOURCE: How do I reformat my Iomega eGo hard drive so that
First of all, connect the Iomega to you mac, make sure it powers up and is detected by the Mac. Now follow these steps: ( It's important to note the Drive before you begin this task so that you may not make any mistakes.)
  • Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
  • Select the disk that needs to be formatted on the left.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to your Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on Feb 08, 2011
bronk50
  • 27725 Answers
SOURCE: I have a iomega
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on Mar 30, 2011
djbr1ck
  • 158 Answers
SOURCE: I have purchased a toshiba
If you are using a mac go into applications then utilities and run i believe its called disk utility and you can use that utility to format the hdd
Posted on May 12, 2011
I want to use in my mac osx mac book pro
Hi Carmen; just plug it in to your system's USB port and format it for use with a mac os according to the provided instructions.
According to the manufacturer: Mac:
  • Built-in USB
  • Mac OS X 10.4 - 10.6
  • 128MB RAM
  • Drive must be reformatted for use with Mac (instructions included)
Mar 19, 2015 | Iomega 500GB Prestige USB 3.0 Portable...
Circuit board... is a clicking noise..
Hi luistuj
Your HD is about to die ; Back up and save your data and drivers at once !
Best regards ,
fanaudi .
Jun 29, 2011 | Iomega eGo BlackBelt 500GB USB 3.0...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
How do I reformat my Iomega eGo hard drive so that it is compatible with my Mac? OSX 10.6.6 The current IOmega format is FAT
Good Luck.
Feb 08, 2011 | Iomega 500GB eGo Helium Portable USB 2.0...
My iomega 1tb is "read
Any Hard drives before getting to used with MAC OsX has to be formatted according to the MAC file system...
I think that is the problem you are facing...
Make sure your hard disk is not formatted for any windows OS and try to reformat for MAC OsX...
It should work...
Dec 09, 2010 | Iomega 33089 250 GB Hard Drive
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 28, 2010 | Iomega 500GB eGo BlackBelt Portable 34621...
I want to restore my mac back to factory settings
There are 2 ways this is most commonly accomplished: 1: You could use the original OSX disk to reformat your MacBook and restore it to the factory settings. You'll need to click on "install Tiger" after putting the CD in and it will restart the mac. A dialog box will come up, click on options, then choose "erase and install". This will erase the ALL DATA so make sure that is what you really want. If you do not have the disk, proceed to step 2.
2: Create a new user account on your laptop. After you create the new account, log out then log back in and erase the old user account. This will delete all the personal files from the original acoount. However, the best way to actually get it back to factory would be step one because step 2 does not actually delete or reset any settings that were modified by the original user account. If possible, always try to procure a disk when restoring. It is definitely the better way to go. I hope this helps you! Please remember to vote if this helped.
May 08, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Displays No Disc on TV
Hi jasnarysheuv,
Did you fix the problem you had? If so could you tell me what you did? I formatted my Iomega Screenplay HD Mulitmedia Drive (500gb) last night on my mac and now it displays 'no disc' when I hook it up to my tv.
Any help would be grateful.
Sep 28, 2009 | Iomega ScreenPlay
Ticking noise
Ticking noises are indicative of major hardware failures. As no HDD manufacturer actually warranties data, if you have important files on it your drive, you will likely need the help of a pro.
If you have all your data backed up elsewhere(including on the Mac), contact Iomega and have it replaced under warranty.
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/cci/product.php
If you do need files recovered, let me know as well as your region and I will recommend a good location.
Chris
May 22, 2009 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Iomega 500GB eGo BlackBelt Portable  34621 500 GB Parallel Hard Drive Logo
114 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
