Question about Fujitsu Siemens Siemens Silver Line S5 15" LCD Monitor
I want to buy a Fujitsu Siemens Lcd adaptor - Fujitsu Siemens Siemens Silver Line S5 15" LCD Monitor
  • 111 Answers
SOURCE: Fujitsu Siemens AMILO D-7830
HI! Yes you can upgrade your Hard drive from a 30GB (std size) to as much as 120GB. The only thing yu need to be sure of is that you need to buy a IDE 2.5" HDD which is a little bit hard to find but is still available. Try to google some suppliers online.
Hope this Helps.
Posted on May 20, 2008
  • 111 Answers
SOURCE: Fujitsu Siemens Amilo d7830 hard drive
Yes, you can up to 120 GB IDE 2.5" HDD. You can buy it from any PC store near you ar order online.
Hope this Helps.
plettdoctor
  • 121 Answers
SOURCE: The black plastic ring at the end of the adaptor
It now has a bad connection and SPARKS all the time and therefore gets hot like that. Replace the unit or get that very delicate connection repaired
Posted on Jul 06, 2009
  • 8 Answers
SOURCE: In my fujitsu siemens lifebook p7120 is broken lcd
look up seller smartlaptopparts on ebay, seller has 4 month warranty on new screen, free shipping 148.00 or best offer
Posted on Feb 15, 2010
budmrtn
  • 11361 Answers
SOURCE: Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 13, 2010
I have had my fujitsu siemens for nearly 4 years. When I first go it I had huge problems connecting wirelessly. BT did however seem to sort the problem. It was fine for 2 years, but again I'm having to use...
Yes if it's just Bluetooth you're trying to get to work by a new BT dongle. If wireless and BT are on the same card buy a new BT/wireless card This one Desktop 802 11ac Wifi Bluetooth 4 0 Dual band 1300M Wireless AC PCI... Works great. Try to stay away from Intel I had to replace two of them in the last six months. The link above uses Broadcom and works fantastic.
Jun 28, 2017 | Fujitsu Siemens Computers & Internet
No electricity on screen. How do I connect LCD doesn't work
Which is cheaper:
* spending $50 to $75 to have a qualified technician "trouble-shoot"
* spending $50 to $100 to buy a used 17" (not 15") LCD monitor?
Jul 31, 2010 | Fujitsu Siemens Siemens Silver Line S5 15"...
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Uninstall network driver for fujitsu siemens scaleo c
go to device manager by typing in start search device manager. under network adaptors right click on the network device you want to uninstall. click uninstall.
Apr 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Fujitsu siemens not seeing wireless networks
Go Fujitsu Website and support, download drivers and download the correct WIRELESS NETWORK DRIVER and/or ADAPTER drives. Select RUN and reinstall them (all).
If that does not work then it may be the network adapter which may be behind a back flap. Remove and Replace with same part. Actually its easier just to buy a USB or PCMCIA Network Adapter from Radio Shack to plug in to your Notebook, comes with software and driver installation disk about $40. This is generally the best solution as it works independantly as a "plug in", easier to install if notebook's built in Network Adapter is defective.
Sep 03, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
The black plastic ring at the end of the adaptor pin is slightly broken. When inserted into the laptop it heats considerably. I have a Fujitsu Siemens Amilo Li 2727
Jul 06, 2009 | Fujitsu Siemens (IPAD142-RFI) (IPAD142RFI)...
Fujitsu siemens laptop wont boot up
hi!!!
do you have the adaptor of your laptop?
Nov 03, 2008 | Computers & Internet
Wireless switch
I don,t think you have a wireless enabled machine..you will need to buy a usb wireless adaptor like a belkin,pacom. Etc..THese are only about £12-15 look on ebay..
Jan 02, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens Siemens Silver Line S5 15" LCD Monitor Logo
77 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
