Question about Sony DVP-NS55P DVD Player
Difficulty installing Sony CD/DVD Player Reference Guide DVP-SR500H, attempted to install, the counter comes up but not the screen disply, have set my TV on AUV1 and tried AUV2 & CV1, nothing happens when I press DISPLAY using the remote, the DVD gives a load indication but not playing the DVD. What should I do next or if their are any installing in my area, please advise. 7206 Gloria Drive, Sacramento, CA 95831 (916) 955-0669
  • Sony Master
  • 2,045 Answers
What cables are you using to connect DVD to TV set?
Posted on Jul 02, 2017
  • 398 Answers
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Posted on Sep 01, 2007
SOURCE: Sony DVP-NS57P all region
try thomson
Posted on Feb 04, 2008
  • 3 Answers
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
Posted on Oct 12, 2008
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
  • 19396 Answers
SOURCE: A Sony RDR-GX210 DVD player I can play a CD -
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Posted on Sep 08, 2009
Testimonial: "Haven't tried it yet - but will let you know if successful thanks - Allan"
Why does my dvd player read,will not play disc?
IS this a dvd you recorded or a commercially made dvd? If youmade it yourself, pop it in the computer and look at the format it was recorded. when the dvd player reads the dvd does it come back with an index of some sort?
Jun 06, 2014 | Sony DVP-SR500H DVD Player
Phillips codes
Download a regional code *.iso file (search google, there are many), burn it to a dvd and place it in the machine to install. If it does not install automatically check the manual for install instructions.
Dec 15, 2013 | Sony DVP-SR500H DVD Player
Sony dvp-sr500h will not spin and reads error
The error likely is the unit detects the platter is not moving---unless an expensive unit it will be cheaper to replace the player than fix it.
Jun 13, 2012 | Sony DVP-SR500H DVD Player
I played some bootleg movies. And now my Sony DVD player (model DVPSR500H). Will not play Retail DVD's. What can I do? I tryed unpluging it. And that did re-set it.
Your DVD player is now locked to the region of your bootleg movies! Sony only allows a certain number of changes before it becomes locked to the 'chosen' most played regio.
You need to make your Sony DVP SR500H 'Region Free'. Try the following:
1) Switch on player
2) Open DVD/CD tray compartment
3) Using the remote controller, enter 2812
4) Press 9 on key pad (to make it multi region) and then enter or Nav Ctr button
5) Press CLEAR to exit
Good luck.
May 03, 2011 | Sony Televison & Video
Region unlock a Sony DVP-SR500H
Ok here's what I've figured out for Sony dvp sr500h...
To get to the hidden menu, you need to start with the DVD player power OFF
then hit
POWER (to turn the dvd player on)
and you should now see the hidden menu
then go to option 2
then option 4
then this is as far as I can enter codes here but none I've tried have worked....
the ones I've tried so far are 2812, 34570, and 12450
if anyone can figure out the correct code please post here.
Apr 27, 2011 | Sony DVP-SR500H DVD Player
We bought a new Sony DVP-SR500H dvd player. I hooked it up with hdmi cable. It will not eject the tray to load a dvd. It just says "load" - no errors. Not childproof locked. Help!
After NOTHING worked (including tips from other sites) I took it apart and literally forced the tray in and out of the player. Guess what? The damn thing works like a champ now!!!!!
Feb 06, 2011 | Sony DVP-SR500H DVD Player
Sony DVP-NS55P DVD Player Logo
103 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
