Question about ASUS Computers & Internet
I would like some infomation on how to use a memory stick
  • ASUS Master
  • 27,725 Answers
Insert the stick into a USB slot open windows explorer you should the stick(drive)you can save files,data,music,and programs onto this
Posted on Aug 19, 2010
Computer does not recognize going from 3 mg to 4 mg of memory
If the two 512 meg sticks still work in the same slots, then you either got bad memory or some that is incompatible. Return the memory to were you picked it up, and get a different brand. Also double check that your are using the correct memory for your system. This infomation can be looked up on most memory manufature websites (example: Crucial or Centon).
Hope this helps
Feb 03, 2012 | Computers & Internet
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
I forgot my password to my san disk 519mb sd card its asking for 8 numbers or letters how do i unlock it without losing infomation
download password recovery tool for memory card downlaod the password recovery tool and then crack your password
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
I have a Dell Dimension E510 and it makes different tone beeps during and after startup. The computer works ok, but the beeps are disruptive. Seems like there are many more beeps during processing steps,...
When you first switch on your computer it checks certain things to make sure everything is OK and sends out multiple Beeps if there is a problem this is call POST. If you are getting multiple beeps then there is a problem, depending what BIOS CHIP you have and how many beeps you are getting should indicate what is at fault. If windiws is starting ok then it will be a minor problem, the first thing I would check if i was you is the memory. If you have more the one stick of memory installed and one is faulty windows will still start but with the beeping error. Start the computer and goto the control panel and click on System and check what memory that is showing and compare with what should be installed. If its the same then the fault is somewhere else and you will have to give more infomation like what is the system bios and how many beeps.
Good luck.
May 29, 2011 | Dell Dimension E510 PC Desktop
How to chicken?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Firstly make sure your PSP-3000 or TA88v3 PSP-2000 has PSP Firmware 5.03 installed. Check in your PSP XMB go to Settings/ System Settings / System infomation. If you don't have PSP 5.03 installed download it here. Create a folder called UPDATE in PSP/GAME on your memory stick and place the eboot from the archive into the folder. Run the 5.03 Firmware update from GAME / Memory stick and you will have 5.03. The firmware required to run ChickHEN.
Now download the ChickHEN R2 release from here. Open the CHickHEN R2 archive and place the folder inside Slim with gif images into your PSP memory stick location like so PSP/PHOTO (later it will be PSP/PHOTO/ChickHEN). Now place the h.bin into the root of your memory stick pro duo. Where the folders PSP, MUSIC etc are located.
Ok next step place the memory stick into the PSP. We have found this step helps ChickHEN boot with less attempts, go your PSP XMB, to settings and Restore Default Settings. Your PSP will reset, now go back into settings and turn off UMD Auto-Start and UMD Cache. We found ChickHEN loads in 2-3 goes after doing this.
Now go into Photo / Memory Stick and ChickHEN. And wait, you will see five egg giff images, these will start to load thumbnails. Your PSP may freeze and reset. Just keep retrying and ChickHEN R2 will load up....But if you see flashing colors, your PSP will reboot into ChickHEN your homebrew ready!
With ChickHEN R2 loaded now starts the fun part. (P.S You can put your PSP into standby now so you don't have to go through the whole process again)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Sony PlayStation Portable (PSP) Console
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
Wont read memory stick
are you sure you have put the memory card in right try turning the psp off and putting the card in then starting up the psp again to see if the card is there i am sorry if this does not work but could we have a little more infomation.
Mar 07, 2009 | Sony PlayStation Portable (PSP) Console
How do I download infomation from my memory stick to the computer? Step by step
1) insert it into a card reader, then connect the card reader to usb drive.
2) Then go to my computer there u will see a removable drives click on it then select the files u want to copy then right click on it select copy.
3) Double click My Computer and double click C:\ drive, (make a new folder if u want to) then copy all the pics on it by right click on it and select paste.
Aug 01, 2008 | Computers & Internet
Computers & Internet Logo
129 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
