Question about RJ Tech RJ1500 DVD Player
I have the rj 1500 dvx II- I'm having trouble with the cd tray not being able to eject, seems to be stuck for some reason. I don't remember how long ago I bought and wanted to see if they have a warrantee on it. If not is their a service department that you can recommend to me in the san diego area.
  • RJ Tech Master
  • 17,130 Answers
Normal warranty cover maybe for a year unless extended. What could be tried is to open the side screws and remove the covers. Then you can see the loading mechanism , the main loading off the CD mechanism is coupled to the eject drive. So only after the optical head moves down will the Cd be able to come out with the tray. So look carefully and you will be able to trace the logical solution to manually turn the gear to move the mechanism to eject. If there is no jamming of the mechanism, tighten all connectorrs just to confirm the connections. If not the loading motor or the motor drive IC/controller IC is faulty.
If not familiar try to search on web for nearest service centre.
Hope you try this out. Good day
Posted on Aug 19, 2010
Testimonial: "thank you thay was very helpful"
Warning Light at parking position will not go off. How do I control it? Warning light at CD eject will not go off, how do I control it?
first check brake fluid level add if a bit low.
if cd eject light is always on check cd caddy if you have stuck cd's
Apr 22, 2015 | 2003 BMW 325
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
Disney cars TV doesn't eject. The DVD seems to be stuck. Does anyone know how to fix that?
CD loading mechanism fault. Contact any service technician. Sometimes, a broken loading belt might be the reason.
Gopakumar Gopalan Google
Mar 25, 2014 | Disney Televison & Video
My cd is stuck and the eject button won't eject it. Is there any way I can get it out?
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 10, 2011 | Dell Inspiron One 2305 Desktop Computer...
Hi, I can't get the magazine out and it reads CD ERROR on the stereo. i've tried to eject it using the button and can hear it making noises as though it is trying but it doesn't come out. i...
It seems so that the disc or the loading mechanism has jammed . Sometimes CD's which have labels or even warped ones( spurious types) can be stuck up as it will not move freely in loading thereby getting stuck in the mechanism.
Also sometimes the loading motor can slip on the pulley with a higher torque or the gear or belt can slip off-- since you can hear the noise when eject is pressed.
The best way is to remove power, open the covers and use a soft tool like a screw driver to push the struck up disc or manually rotate the gears to release the loading and thereby eject the tray out. Now inspect all the disc before you put then back inside as one of them is a suspect.
Aug 04, 2011 | Sony CDX-T69 6-Disc CD Changer
It won't eject and makes a noise when I press the eject button
Sounds like the disc is stuck.
Look for a pinhole around the CD-Tray area, and straighten out a paperclip, and shove it straight back into the hole.
This should release the tray lock and eject the disc enough that you can remove it.
Once you have the disc out, try the eject button and see if it returns to normal operation (you may need to unplug and plug back in the unit)
Feb 27, 2011 | Bose 3 2 1 GS Series II DVD Home...
My xbox 360's disc drive not opening
Thank You Luke-7 yes it's jammed ,stuck ,seized,
Common problem ( Stuck Tray)
The reason is the eject motor is either to weak to break open
the magnetic seal created between the spindle and the hub
holding the disk firmly in the drive or there is too much friction
in the gear assembly causing the motor to stall-out
To get the tray to open press the eject wait one second
and then Firmly (HARD) slap the top of your console right
over the CD rom drive this will break the seal and release
tray allowing it to open.
The console should be open ,the Rom drive removed
and open and thoroughly cleaned out .plus I like to gap
the hold down magnetic so the eject motor can release
the tray with less force.
If you have any Questions feel free to ask
Rob
Apr 22, 2010 | Microsoft Xbox 360 Console
How do i eject a stuck cd from gateway one 710 series I have tried the eject button on the keyboard but will not give it up...
Have you tried the eject button from the tray? If all that you need is a tool to eject the tray without touching the tower, I suggest you to go to this link and download the Eject-CD freeware runtime file EjectCD.exe - approx 30kB. Alternative if your tray is locked and can not open with the above methods, you have to locate a small hole in the front panel of the tray and put into that hole something like a connector (for papers) or a strong wire in order to push the internal system to open.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 08, 2010 | Gateway ONE GZ7108 All-in-One Desktop PC
Jvc dvd receiver xv-thu1 says locked when i press eject
Hello Dude !
There reasons why your DVD tray won't eject
1, a cd got stuck inside
2, Motor belts are loose
3, Loading motor faulty
4, Main loading gear damaged
5, Somebody must have pushed the loading cd tray forcing it to load and waiting for it to load the cd by its self so it has jumped its setting .
If so you have to remove the loading tray and put back correclty then it should load by its self .
Good luck
Nov 13, 2009 | Televison & Video
RJ Tech RJ1500 DVD Player Logo
85 people viewed this question
Top RJ Tech Televison & Video Experts
Electro Med Services...
Are you a RJ Tech Televison and Video Expert? Answer questions, earn points and help others
