Question about Toshiba Satellite A215-S4747 Notebook
The computer is not booting up and if it comes on it automatically shuts off.
  • 64 Answers
It is likely due to overheating. I would leave your system for a bit to allow it to cool down. When you start it, prop it up from a flat surface a bit simply by putting a pen or a small article to allow for some airflow under it.
Usually a laptop not booting and shutting itself down is related to a hardware failure, low battery, or safety shutdown in case of over heating.
Give this a go, Let the laptop sit for 10-15min while off. Then unplug the laptop and remove the battery. Then plug it back in without the battery. See if it boots. If it is still shutting off. Contact the manufacturer for support or a local technician. -Ravi Shanghavi
Posted on Aug 19, 2010
Computer won't boot up
You have to give more information about the behaviour..You computer shuts off..when exactly ? Has it passed bios check? Are windows loading or windows screen appears..?Can you open bios setup while booting?
However..shutting off..seems to me that the Power Unit may have failed
Nov 11, 2013 | Gateway Computers & Internet
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
I don't know my computer shuts down automatically.
In order to advance on the resolution path, could you please check the following :
This problem could come from a power saving mode that we see more often these days.
You must ensure that there is any setting in the BIOS that could cause the machine to shutdown ? If you want to make sure it's comes from the BIOS or from the Operating System (I suppose you use Windows), I recommend you to boot a linux live CD on a usb stick or CD. My recommendation would go to download and burn the latest Kubuntu CD, then boot on it (without installing it of course), and wait for 2 hours to check if the computer did stop or not.
Jul 09, 2011 | Computers & Internet
When i shut the notebook down and tryed to load it back up it will not load it gets to windows is staring and then restarts the process
Hi there!
Your computer may have an error that is causing the computer to restart, Try this one, when you turn on the computer start pressing f8, then advance boot menu should come up, after that select, disable automatic restart then the computer will start booting to windows then it should display the error, if it still stays on the screen q/o showing anything, do the f8 process again and this time select safemode.
Hope this helps!
Jun 01, 2010 | Computers & Internet
Why does startup repair keep popping up on my laptop when i turn it on my sony laptop
This is the system error and it comes when the user doesnot shut the comp in proper way.//
it can also come if due to some reason the comp is shut automatically//
to get rid of it try last known good configuration.
shut down the comp// restart and immed start hitting f 8 cont to get the advance boot menu//
select LKGC and once that is done hopefully your computer will boot perfectly//
May 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Boot/Startup repair problem
Microsoft updates do it again!!!
while the PC is booting up his F8 repeatedly, if it lets you into the sub menu boot into safe mode and perform a system restore, take the computer back to before you did the updates, if this works and your computer is restored, turn the automatic updates off
kind regards and please don't forget to vote
Dec 12, 2008 | Acer Aspire 6920 Notebook PC
Laptop boots then shuts automatically off
i thinkl you got a virus,, i suggest you to restarted than scan your computer.
Feb 23, 2008 | Toshiba Satellite A85-S107 Notebook
Trouble starting compaq presario F551AU
Hey I apoligise for the late reply,
Ok, first off when you turn off the computer without shutting down, windws does not get enough time to wirte necessary data to the disc, this does not always cause aproblem because sometimes there are unpredictable events such as power failure..
You might need to format your hardrive to fix this problem
To do this boot with the windows cd, it will say press any key to boot from disc. (YOU MIGHT NEED TO SET YOUR BOOT DEVICE IN THE BIOS(SETUP))
anyway fisrt off try a fresh install, leaving your current file system intact. Id that works then you will still have all your data on your disc, If not then you need to do a complete format.. Good Luck
Dec 29, 2007 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Toshiba Satellite A215-S4747 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
