Question about GE Refrigerators
GE Freezer on top GTS22IBMBRWW The freezer and regrigerator are not cooling but the fans are running. They shut off if I lower the temp controls to zero.
  • chappy44 Aug 19, 2010
    My GE gts22ibmbrww freezer on top is running but not cooling. the freezer and reefer fans are running but both are blowing room temp air. I have cleaned the coils. The fans both shut off when I lower the thermostat controls to zero.
  • 17,970 Answers
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky.... they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Keep updated.
Posted on Aug 19, 2010
    Genius:
  • 1,478 Answers
If your refrigerator is not cooling, the problem could be any of the following, follow the steps below one after the other to fix the problem of your refrigerator not cooling.
First of all, the most simplest thing to do is to check the temperature. It might have happened that the temperature control may have been turned off unknowingly, which is the reason for the problem. So if that's the issue, just set the refrigerator at 37 degrees and you are all set.
Poor coiling leads to a heavy frost build up on the evaporator coils. A frost build up, specially on the ceiling of the freezer, is a sign of problem in the self defrosting system or damaged gaskets of the doors. Therefore, check if the refrigerator is facing such a problem and defrost the refrigerator. It would not cool well if the defrosting is not happening properly.
A dirty condenser may be the culprit for your refrigerator not cooling well. What will happen in case if the condenser is dirty is that it will cut off the extra load. That work is done by the thermostat on the side of the compressor in case the refrigerator heats more than usual. To rectify this problem clean the condenser coils using the vacuum cleaner. These are either behind or beneath the refrigerator
In case the refrigerator is not leveled, that too can lead to the refrigerator not cooling properly, because if the level is not right, the door of the refrigerator may not close correctly, causing cooling problems. If this is the case, it might be necessary to ensure that refrigerator is at level and is slightly tilted back. Do some adjustment to get that correct level using a wooden block or see if the screws on the leveling legs need some looking into.
Check out the door seal. If the door seal is worn out, it will definitely result in frost build up and that won't allow the door to close properly, thus the problem of refrigerator not cooling. In addition to that there can be a problem in the door even if the level and other things are fine. You would need something to do about the door then. May be loosen the hinges and fix them in order to get the correct position of the door. Eventually tighten the hinges.
The food and freezer sections will go dysfunctional if the evaporator fan is not working properly. This is because then there will be no airflow to the freezer or the other sections of the refrigerator. Confirm if both the fans are working well by listening to the sound emitted by them. There is a possibility that one may work and the other wont. For that, may be you would have to look for a blockage or something in the one which is not working. Even after doing this you do not find any problem in the fan, you may need to replace it. This are are the general procedure for troubleshooting refrigerator not cooling. with all this, you should be able to identify and fix the problem.
Take care.
  • Jimoh Adeleke Muyideen Aug 19, 2010
    Check the thermostat for temperature setting. Make sure your freezer is
    not too stuffed and that there is enough space for air flow. Check for
    the restriction of air flow in the vents. Clean the coils of the
    condenser if found clogged. Also look out for clogged drain tube and if
    there is a leakage of the refrigerant. Test various components such as
    temperature control knob, evaporator fan, defrost timer and the door
    switch.
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
I have a stainless GE profile PSS26SGPASS side by side fridge and suddenly the freezer and fridge wont hold the temp settign I put. The fan works, the controls work to lower the temp setting but it isn't...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 26, 2011 | GE Refrigerators
The regrigerator does not cool. It makes noise like it is on but never gets cool.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 21, 2010 | Whirlpool Refrigerators
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
Frig side does not cool. freezer side cools
Apr 16, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Maytag MSD2756GE is not cooling on the regrigerator side but is freezing ok. What could be the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 13, 2009 | Washing Machines
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
GE not Cooling
FREEZER ON THE TOP OR BOTTOM ?
Dec 19, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
