Question about Refrigerators
We have a 2009 Holiday Rambler 42 Ft. RV. The problem is with the self defrosting Freezer. It is a Dometic with an ice depenser/water. The model number is: either NEA 1402 or NDA 1402. (Exterior description): the doors are side-by-side. The freezer door has an ice/water dispenser. Even w/ the bottom of this dipenser the seam between the doors makes a 45 degree cut to the right and then straight down again. Here's the problem: The channel within the freezer compartment that collects and drains the defrosted water fills & overflows w/ ice. I have been told that if the heat strip at the bottom of this channel isn't working the entire unit won't work. The unit DOES work but it DOES SEEM that the defroster strip isn't working which would explain the water freezing before it can drain. I have defrosted the freezer and poured water into the channel and it exits the drain tube behind the outside access panel so I don't think there is anything in the tube. FYI: I had a water leak below the refrig, a steady drip. I took it into an RV place for service. They said they thought it was the defrost line leaking. I said it was a steady, timed drip and seemed to be a PRESSURE leak. I'm a customer and CAN"T be right, so they pulled down HARD on the drain tube to remove any kinks and declared it fixed. When I got it home it was still dripping. I found the REAL leak 5' away in a kitchen faucet supply line and tightened it and stopped it. BUT, ever since that RV placed "fixed" the drain line the freezer has been freezing up. Unfortunately we will not be near that dealer for many, many months. This MAY NOT be connected but I wanted you to know everything about the situation.
  • 3 Answers
If the drain tube heater is inop. you will get code 13 on the led panel
Posted on Dec 30, 2010
I have a 1984 holiday rambler how do I hookup city water I have three hookup s two that are together and one by itself
guessing here
one would be to the fresh drinking tank
leaves two to choose from
does the RV have two types of taps ?
how many water tanks on this model ?
have see one layout with chemical toilet and normal house taps at its sink
or kitchen sink with multiple taps
Jun 22, 2016 | Holiday Rambler RVs
Gas 1999 Holiday Rambler Endeavor. How do I remove the dog house?
1999 Holiday Rambler Endeavor 36 WGS Class A Motor ...
? 11:40
https://www.youtube.com/watch?v=7nsTuFfPZLE
Jan 17, 2014 - Uploaded by Parkwayrvcenter
Can you find Holiday Rambler Quality with a Slide Out and Low Miles for ... Normally that is impossible but Parkway RV Center has done it again ... ... Remove all; Disconnect ... 1999 Holiday Rambler Endeavor 36 WGS Class A Motor Home with .... 1997Holiday Rambler Vacationer class A gas motorhome ...Missing: house
Jan 07, 2016 | RVs
Owner manual
Contact the manufacturer of the coach for their owner's manual. However, each appliance will have a separate owner's manual form its perspective manufacturer, i.e., Water Heater = Suburban, A/C = Dometic, Refrigerator = Norcold, etc.. There will not be a diagram of electrical or plumbing as a majority of the RV manufacturers do not publish that information.
Jul 22, 2014 | Holiday Rambler 2011 Mintaro 31BHDS
Ice in the bottom of freezer
Greetings,
the drain is clogged most likely...remove lower shelves, baskets, remove rear panel if self defrosting.. find the drain hole and use a hair dryer or hot water to defrost ice..once the surface ice is off...you will need to make sure there is no ice in drain tube going down under freezer. use a squeeze bottle with hot water and force it into drain. do this repeatly until water runs free down drain....Bruce Denton
Jan 09, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Freezer not defrosting
Hello pumpguy2
Welcome
You said, you have a Kenmore bottom Freezer Model 596.73503201. It works fine but the freezer has stopped defrosting. Any suggestions?
It is supposed to be auto or self defrosting.
What do you mean you are getting ice forming in the freezer?
Waiting for your response and more detailed explanation.
Huuum
Oct 01, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dometic Top Freezer RV/TT Refrigerator
You have a switch inside the door. Turn it on this actually keeps the light on inside. This may help with your humidity problem. Also check to make sure the drain out side of the coach is not clogged you should see water coming out
Aug 05, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
228 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
