The machine and washing smell,how do I clean the filter(s)?
  • 712 Answers
There is a screw attached to the drum. You can remove it very easily and pull it hard to open it. Clean the components under running water.
Posted on Aug 19, 2010
The machine has a mouldy smell and so do the clothes after washing
clean out the water pump and filter that empties the machine. if its blocked up and not working to full potential,some old water will be left in the bottom of machine after each wash. this will be whats causing smell
Aug 28, 2017 | Washing Machines
Every so often there is a Smell in t from the Washing machine we do clean out the Filter in the Front of the Machine, never any Fluff also run once a Month the Cleaning Cycle any Suggestions
change from powder detergent to liquid detergent
powder remains in the wash tub as a sludge build up which occasionally smells or leaves black marks on the wash
Oct 21, 2016 | Washing Machines
What do I put in the machine for the tub clean cycle?
john low temperatures washing can cause the machine to smell
if it was me i would set the machine to it's hottest wash and use a descaller or bleach and washing liquid ,after wash has finished give it an extra rince cycle./ scrum around rubber seal behind door before starting wash. check pump filter is clean,
Sep 22, 2016 | LG WM1814CW Front Load Washer
Low water level
Clean the intake filter and drain pipes
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
How to Clean the Inside of Washing Machine
Sep 10, 2016 | Washing Machines
My washing machine is beginnig to smell inside the drum is it because I wash on a quick cycle
It's very common. There is a high efficiency washing machine cleaner you can use in is as well as cleaning the gap in the seal for the door. Some machines also have a filter to catch small objects and if that is not clean it can smell as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/justin_3ae27a9d61d6acd4
Apr 17, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine smells!!
Run a load of just water and chlorine bleach. Run it HOT. After that, use bleach to clean the door seal and seat.
Apr 10, 2010 | Zanussi ZWF1640 Front Load Washer
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
