Question about Epson Stylus CX4600 All-In-One InkJet Printer
Lost my manuel !
How do I clean the heads on a Epson stylus CX4600?
  • 35 Answers
I also recommend you read this solution here, for manually cleaning your print heads.
Doesn't waste ink, and generally works better.
http://www.fixya.com/support/t743789-printer_will_not_print_even_though
Posted on Aug 13, 2008
  • Jefferson Casavant
    Jefferson Casavant Aug 14, 2008
    The ink heads are clogged with dried ink.
    Follow these steps:
    1) Begin saving money for a new printer.
    2) Lift the scanner to get at the ink. Remove the cartridges.
    Take cotton swabs and alcohol and clean all the ink off of the top of the heads (located in back. they're the pointy things) until you can see the holes. THE CRUCIAL STEP: Insert something-small enough to fit in the holes-all the way through every hole in every head. This should clean out the dried ink and allow your printer to continue to work.
    3) If step two doesn't work, I really hope you did step one.
    Don't buy an Epson. They also have this other feature which prevents printing when one cartridge is empty. Even a color cartridge. I recommend a Canon, if you like name brands, or an HP.
    To Clean the Main Print Head
    Remove the ink cartridges.
    There are two screws on the gray ink lid, visible when open. Unscrew them, and then remove the lid. There are three screws inside the ink carrier. Remove them.
    Get a pair of Needlnose Pliers and a flat-head screwdriver.
    There is a plastic plate near the front of the ink carrier, at the base. It forms a right angle with the left side. On the top of the left side portion of this plate, insert the flat-head screwdriver and lever the plate inwards. It will come off to reveal two gray cables. Take the needlenose and grasp one of the ink heads. Pull upwards and towards yourself. When you can, remove the two cables from the ports in a straight outwards direction. This should free the main print head from the rest of the printer.
    At this point, you can purchase a new main ink head or wash your old one. I am cheap and chose to wash the old one.
    Get a small tub and some rubbing alcohol. Pour the alcohol into the tub, and immerse the print head for several hours, shaking every once in a while.
    Now comes the long cycle of cleansing the head totally. Have a rag ready. Remove the head from the alcohol, and wipe off the smaller print heads (the points). Then, (here comes the crazy part) put it up to your mouth and put as much pressure as you can into all four, for about ten seconds. Turn the head over and wipe off the ink that has come out. Repeat until no more ink comes out. Then, immerse the head again, remove, and allow to dry naturally (or possibly by blowing on it). Make sure the two ports for the cables are dry.
    Reassembling the printer/Inserting a new or refurbished head
    Before pressing the head back into place, connect the cables, right one first. There is an indentation on the top side of the head for the cables to fit. Then, place the head snug into the ink carrier, front side first, angling towards the back, until it is flat. Reinsert the plastic plate. There is a small tab on the right side of it, and that goes into the slot near the end of the right cable. Press the plate back into place gradually moving towards the left, starting from the tab. Put back all three screws, two on the top and one on the middle right. Reattach the cover, with the two screws on the left and right. Reinsert the cartridges, and you should have a working printer.
    Genius:
  • 1,447 Answers
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Pls dont forget to rate solution, thanks!!
Posted on May 02, 2008
2 Suggested Answers
SOURCE: Epson stylus CX4600 / lost manual
warning from printer, internal parts near the end of their service
Posted on May 18, 2008
Just got a epson stylus cx4600 giving to me but has no software { cd } to install it on my computer. How do i get drivers software to install it?
Go to this page for the main support page for this printer:
Epson CX4600 Support
For software click on Drivers & Downloads. You need to select your operating system.
NOTE: You need to download the printer driver and the Twain driver. Installl the printer driver first, then the Twain driver before connecting the printer to your computer. Click on the little + signs next to the software headings for special instructions.
You can also obtain manuals from the support link above. In fact I would bookmark that site for future reference.
Thanks for using Fixya.
Jan 13, 2010 | Epson Stylus CX4600 All-In-One InkJet...
I lost the CD installer for my Epson Stylus how can i install my printer again?
Go to the Epson website, www.epson.com. Click on the support link. Lookup your specific printer model #. Download and install the software/drivers which pertain to the operating system you are running. After the installation you will be all set. Hope this helps.
Apr 28, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson cx4600 tubes are clogged
hi there
first you can try cleaning the heads of the cartridge with the software which has come along with epson this will solve your problem if dont then please change the cartridges or call epson service center they provide u onsite warranty
Nov 08, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus cx4600 all in one
remove the printer inks & use soft issue paper to clean the printing head. how long have u be using this ink on the printer?. check for the ink level if its too low, the output will be very faint.
thanks. let us know if we should add more tips.
Oct 05, 2008 | Epson Stylus CX4600 All-In-One InkJet...
May 02, 2008 | Office Equipment & Supplies
EPSON CX4600 clogged
I have only just joined the forum but thought the attached may help.
I don't know the CX4600 so I'm only offering an idea.
www.hardwaresecrets.com/article/178/1.
Hope it helps
Feb 18, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Possessed epson stylus printer #cx4600
i would suggest this http://www.supermediastore.com/cleaning-cartridge.html or a similar product from a different supplier..
Happy New Year
John
Dec 05, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Paper comes out blank
epson cx4600 prints blank paper replaced ink cartages .same problem
Dec 02, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 all in one printer, scanner
Under Maintainance in the properties of the printer it gives you the option to clean the print heads. Should work
Feb 19, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
