Question about Xerox XG-91D 19" LCD Monitor
My Xerox XM7-20w LCD Monitor starts, display briefly (about 1 or 2 secs) then goes back. any solution
5 Suggested Answers
SOURCE:
frankzjm
  • 191 Answers
SOURCE: Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Posted on Feb 07, 2009
  • 37 Answers
SOURCE: Samsung lCD monitor displays for 1 sec
This sounds like the backlight in your monitor has gone. I have seen this a bit in samsung LCD's. You can usually tell this by getting a torch and shining it on your screen. By doing this you should be able to see the display on the monitor.
The first thing to do is check the monitor is under warranty. Samsung have fairly lenghty ( 3 years i think) warranties with them. If it is under warranty they will replace it no questions asked.
Otherwise, you could try your hand at replacing the backlight yourself. I'm not too sure of what is involved in this, but know of people who have done it and said it was fairly easy.
I hope that helps, please don't forget to rate my answer if it does.
Posted on Mar 20, 2009
budmrtn
  • 11361 Answers
SOURCE: Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Posted on Mar 19, 2010
budmrtn
  • 11361 Answers
SOURCE: my Xerox XG-91D LCD Monitor start, display
I would try VGA to VGA hook up first to narrow down the problem before start taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). See example of failed monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Posted on Apr 01, 2010
My Xerox XG-91D LCD Monitor start, display briefly (about 1 or 2 secs) then goes back. any solution in this case? mention that i use with a dvi-i adaptor on a vga graphic card. thx
Apr 01, 2010 | Xerox XG-91D 19" LCD Monitor
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
My siemens LCD monitor back light turns off after 1 sec
You need to check out caps in the power supply section first, then check the backlight inverter circuits for bad fuse, transistors. It can also be bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 05, 2010 | Fujitsu Siemens Siemens Basic Line B15-1...
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
Aug 03, 2008 | Dell E207WFP LCD Monitor
Xerox XG-91D 19 in. Flat... Problem
If you look on the back of the monitor it has the name of the manufacturer - which I googled and found this warranty information: http://www.sylvania-displays.com/Support/warranty.html
If you already know that your monitor is out of warranty but want to try to figure out what's wrong with it, these are the contact numbers:
California:
PTI
7373 Hunt Avenue
Garden Grove, Ca 92841
Phone: 714-799-3899
Fax: 714-379-6290
Hours: 8AM to 6PM Pacific Time
Texas:
PTI
10849 Kinghurst Suite # 120
Houston, TX 77099
(281) 530-4100
(281) 530-4104 fax
Hours: 8AM to 6PM Central Time
For further warranty information, please contact our Customer Service Department
Call our toll-free service number at 1-800-776 8439 for out-of-warranty service rates.
Jun 23, 2008 | Xerox XG-91D 19" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
LCD Monitor
is it connected to a PC? is the power source good 110v or 220v?
Mar 30, 2008 | Computers & Internet
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Xerox XG-91D 19" LCD Monitor Logo
176 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
