Question about Mitsubishi VS-55609 55" Rear Projection Television
I am about to buy a used 60inch Mitsubishi big screen TV...there's a little scratch on the screen is this something that can be fixed easily?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
No, if the screen is scratched it would have to be replaced---most are well over 100 in cost---if not too bad this should be a bargaining point to use---set not worth as much with scratched screen.
Out clear screen is protective only and anti glare as well.
Do not try to sand or buff it out--It will just make it look worse.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 19, 2010
I have a big screen tv and little tiny white specks are starting to come behind the screen. What is causing this?
There is a fault with the light engine.one of the chips in it is faulty .there is a you tube video showing the fix.unfortunately the chips cost around 150 pound.
Oct 19, 2014 | MITSUBISHI DIGITAL ELECTRONICS MITSUBISHI...
Where to find replacement Diamond Shield at reasonable price
Check this link I believe they can help you with this http://fixmymonitor.com/
Hope that helps..........
Aug 01, 2008 | Mitsubishi WS-65813 65" Rear Projection...
I have a 60inch 1080p big screen Mitsubishi tv with atleast a 1000 little white spots and tv turns off frequently when 1st turned on what is wrong?
The white spots sound like the Optical Light engine has a bad display, they sometimes start with one or two and multiply.
The engine is about the most expensive part in the set, see attached photo of one
Dec 21, 2012 | Televison & Video
Can the front screen of the projection tv be replaced? This one has two big slits down the front. 1999 Mitsubishi Big Screen Tv
i had the same problem with my old tv there is a plastic pane that was badly scratched on mine i had it replaced if there is material behind that that is tore i wouldnt see why it couldn't as long as it is the same texture and thickness preferably the same call your local tv shop to see if there is a special order for the same material
Dec 21, 2009 | Mitsubishi VS-60603 60" Rear Projection...
How to fix a big scratch on a projection tv screen
Is it the screen itself or the protective screen that is scratched. If it's the protective screen, then you can just remove that, but be warned the lenticular screen is now prone to scratches from kids, dogs or a clumsy significant other. But if you feel comfortable with no one bumping into it, then you can remove the protective screen and actually get a better picture quality with no glare.
If it's the actual lenticular screen (one behind the protective screen) then your in trouble and it will cost a pretty penny to get fixed. You can switch it out yourself once you buy a new one, but have two people handy, the instructions on how to replace should be in the owners manual.
Jul 19, 2009 | LG 30FZ4D TV
Mitsubishi Model VS60607 Big Screen TV
There is a store called Big Screen TV Replacement Parts on EBAY that sells screens.
May 27, 2008 | Mitsubishi WS-65807 65" Rear Projection...
TV problems
I have a mitsubishi HDTV 1080 Integrated and the speakers are off and I can't get it back on
May 14, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
1995 mitsubishi 60inch big screen
Probably a solder issue. try soldering around the flyback, line coilsand vertical and yoke plugs. You can get a service manual for 10.99 emailed to you at the following link. they also offer free support to help with the diagnosis of your Set.
http://servicemanuals.vstore.ca/
Feb 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Open Questions:
See all Mitsubishi VS-55609 55" Rear Projection Television Questions
Mitsubishi VS-55609 55" Rear Projection Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
