posted by formaldeamon on May 02, 2008
I had a friend of mine solder in new stk chips, now the top and bottom of the screen is bowed inward. The original chips were stk392-110s and were replaced with stk394-250s. The soldering is excellent and all transistors were checked prior to the board going back in. Does anyone have an idea what the problem is?
Comment by formaldeamon, posted on May 03, 2008
Is service mode convergence done by hardware? Or can I get new chips put in to remedy the problem?
Best Solution
posted on May 02, 2008
im not too sure if those are compatable chips.... if they are then at least you would have to service mode converge the set. something a tech would need to do.
Rating Locked! (?) formaldeamon has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for JVC AV-56WP74 56 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
JVC AV-56WP74 56 in. Rear Projection...
JVC AV-56WP74 Convergence part...
My TV's convergence went out... Answer This...
red color trouble
red color trouble
my projection tv has a red... Answer This...
JVC 56in. is broken
JVC 56in. is broken
My rear projection tv isbroke... Answer This...
52 inch jvc projection tv, cant...
i cant get any movie to fit the... Answer This...
Flashing green power light on...
It?s a 52? RCA HDTV SRS Focus... Answer This...
Repair Service
Find Projection TV Repairman Near You:
