Question about Sharp AR-235 Copier
Hello, I have a sharp AR-M236 copier. I am getting a solid black copy on side 1 and grey on side 2 even though i am making a single sided copy. And there is no sign of the any copy image on side 1. Hope someone can help with this one....
    Habit-Forming:
  • 96 Answers
Hello try to check the corona and the discharge lamp of the drum.
Posted on Aug 19, 2010
Sharp ar-m236 don't copy 2 side
Faulty duplex motor or inverter.
Nov 19, 2013 | Office Equipment & Supplies
Black line on paper.when copy. sharp ar-m236
COULD BE A MARK ON YOUR CARRIAGE.I COULD CHECK THAT FIRST
Sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Sharp AR-M237 Digital Copier
Sharp AR-M236 Fault U2-40
Hello sir; This error code require reset the procedure as follow;
press "#/p" " . " "clear" " . " then enter 16 press start enter 0 press start again, press "clear all" machine will back to normal.
Aug 04, 2009 | Sharp AR-235 Copier
How can install the sharp ar-5316 black and white cartridge
Hello sir; you have to open the side door first and then open front door , then slide out TD cartridge and drum cartridge, it will automatic reset.
Jul 11, 2009 | Sharp AR-5320 Black and White Copier
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
All copies from the glass or file print with dot with grayscale
you need your developer replaced. That will solve the gray blacks/
Jan 14, 2009 | Sharp AR-M700N Copier
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-235 Copier Logo
105 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
