Question about LG WM-2077C Front Load Washer
The soap is not being dispensed during the wash cycle. The compartment is still full after washing.
  • 1 more comment
  • curtisncarol Aug 19, 2010
    I already took the whole compartment out and rinsed it
  • curtisncarol Aug 20, 2010
    What we found was to pull the washer out , disconnect the water hoses and found that there were two tiny metal filters that were packed with hard water sediment. I cleaned them with a tooth brush then replaced everything back as before. After that I ran the washer though a cleanning cycle. And wa la upon the next wash the soap dispensed.. Let everyone know about these two little filters--it saved us a lot of money.
    thanks for the picture it helped a lot
  • LG Master
  • 8,220 Answers
Remove the dispenser and give it a washing in the dishwasher.
SERVICE MANUAL
Posted on Aug 19, 2010
  • 2 more comments
  • Dan Webster
    Dan Webster Aug 19, 2010
    The vent hose did you clear it? You might have remove the top and blow out the hose. Must be some goop in the hose between dispenser and tub wouldn't you think?
  • Dan Webster
    Have you washed out the hose from tub to dispenser?
  • Dan Webster
    TIP: If you decide to remove all of the hoses to the dispenser pay particular attention to how they go back.
    Draw a diagram of where each one goes.
  • Dan Webster
    Dan Webster Aug 20, 2010
    Thanks
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote from my experience with my washer...
I would imagine that yours will be similar and that it will help you..
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Fabric dispenser leaves water in dispenser after wash is done
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Jan 16, 2016 | Washing Machines
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
Soap dispenser will not open during cycle
I have the same dishwasher, have for about 2 years. It took me about a month to figure this out... But, you cannot run it with the flatware rack hanging on the bottom dish rack, you have to move it to hang on the door and you cannot have anything in the compartment under the soap dispenser that is tall enough to block it from opening. Annoying design for sure!
May 12, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
The main wash door doesnt open
switch to pre-measured tablets,and throw the tablet directly into the tank(d/w..)it works better that way anyways...most dispensers are very expensive also
Mar 03, 2010 | Dishwashers
Secondary soap dish won't open
i think you mean jet dry compartment.change dispenser. in some cases there is a kit but its better to replace new dispenser
Mar 02, 2010 | Dishwashers
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Dec 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
LG WM-2077C Front Load Washer Logo
90 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
