Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My Bissel Proheat 2x sprays water continaully without pulling the button. It drains the tank in a couple of minutes. Is there anything I can do to fix it?
  • James Constantine Aug 19, 2010
    Hi Daniel! I gave the wrong model # to you. It's a 8920. The right spray nozzle sprays continuously. Is it possible that it is stuck open and can it be repaired?
    Thanks,
    Jim
  • James Constantine Aug 21, 2010
    Thanks for the help! I took it apart and cleaned the system and it's working great!
  • 4,323 Answers
Hi
Check seals on Clear Water Tank and Solution Tank. If necessary, re-seat or replace seals. Check valve action on Clear Water Tank and Solution Tank by depressing them with your finger. The valve should move up and down. Check valve action on Clear Water Tank and Solution Tank by depressing them with your finger. The valve should move up and down. Replace if necessary. Next you’ll need to check the pump system.
Pull trigger to check spray -- making sure upper handle is firmly positioned onto the lower handle. Water should flow through tubing from the tank to the pump and the red float inside the pump should move up. If it doesn't, replace the pump. Check the tubes for air bubbles as the unit is spraying -- bubbles indicate an air leak that prevents pump from priming.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 19, 2010
  • Daniel Scott
    Daniel Scott Aug 21, 2010
    Hi
    It is possible that it may be stuck or the button may be faulty. It may also have happened due to a faulty flow system. Please follow these steps to troubleshoot the spray system---
    1. Remove SmartMix piston from the main housing and place SmartMix body (located
    beneath the knob on the main housing, inside of the unit) so that it is 1/16" from
    completely inserted.
    2. Replace tanks in unit.
    3. Plug unit in and turn it on.
    4. Pull trigger to check spray -- making sure upper handle is firmly positioned onto the
    5. Check the tubes for air bubbles as the unit is spraying -- bubbles indicate an air leak that
    6. Locate the source of any air leaks and correct them, looking first at the auto load receiver
    (under the tank) and the SmartMix assembly.
    Daniel
    Guru:
  • 632 Answers
The wire connecting the button may have come stuck, You can try replacing the button and wire connected to it, Before you try anything else
IF that fails you can then contact BISSELL Consumer Services at 1-800-237-7691, Who may replace if become defective and under warranty.
Posted on Aug 20, 2010
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
The water in my bissel pro 2X heat will not spray water
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
May 05, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I can't get the brushes to rotate and the water to spray on the bissel pro heat 2x.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Won't spray
I have the red Bissell Proheat CleanShot 2x 9500 and it would not spray water or solution from either the floor or the hand tool. I followed a tip on here and checked the red gaskets. There is one on the bottom of the water tank and one on the solution tank. My red gasket had come off the solution tank and was lodged inside where the solution tank sits. I pulled it out and reattached it to the solution tank. Now everything is working perfectly again. I hope someone else will be as lucky as me!
Aug 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
529 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
